Help replacing failed drive
mpcringe
Hi all,
I'm running a 6x2TB raidz2 on freenas 9.10, and had a drive fail by just disconnecting overnight. Now my pool is in a degraded state. I'm trying to follow the instructions to replace a failed drive, but the guide outlines a process to offline and then disconnect a failed drive. Since I cannot get the failed drive to connect, I'm a little unsure how to proceed.
The output of zpool status is:
Shell
NAME STATE READ WRITE CKSUM
Rosetta DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/7a173b25-2fb0-11e4-a5f0-d05099273f90 ONLINE 0 0 0
gptid/7a61c46e-2fb0-11e4-a5f0-d05099273f90 ONLINE 0 0 0
gptid/7aa29598-2fb0-11e4-a5f0-d05099273f90 ONLINE 0 0 0
gptid/7ae0c5ee-2fb0-11e4-a5f0-d05099273f90 ONLINE 0 0 0
gptid/7b1e2489-2fb0-11e4-a5f0-d05099273f90 ONLINE 0 0 0
7220073043651036793 UNAVAIL 0 0 0 was /dev/gptid/7b5aac75-2fb0-11e4-a5f0-d05099273
f90
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h19m with 0 errors on Tue Aug 15 04:04:43 2017
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
Do I simply plug in a new drive in the place of the failed one and continue from step 3 of 8.1.10 Replacing a failed drive?
Thanks for your help.
MrToddsFriends
Documentation Browser
Yes, assuming you have no difficulty to identify the failed disk for physical replacement. After physically replacing the disk continue with logically replacing it (the device named '7220073043651036793') in the FreeNAS GUI as described in step 3 in that section of the manual.
