Recommended to use Proxmox with TrueNAS in RAIDZ1?
Keyakinan
I want to use proxmox on a Hp microserver gen 8.
My Idea is to use 3 HDDs all 14tb each. Can I give TrueNAS 3x 10tb and a RAIDz1 config. Pfsense some space and leave a little space over for another VM if I ever wanted to?
So I don't use the full space of each drive but share it.
The reason I want to do it like this so I can put PFsense on a seperate device down the road. And still create separate VMs.
And if that isn't a good plan, can I have 3 full disks for only TrueNAS in raidZ1?
thanks in advance.
Patrick M. Hausen
TrueNAS does not do RAID 5. Please read the ZFS primer to educate yourself on how ZFS works:
Giving TrueNAS virtual disks is pretty much always a bad idea. You'll want to pass through a controller (and all connected disks) to the VM, and Proxmox' support for that isn't very mature. But SCALE uses KVM for virtualization, just like Proxmox does--seems the thing to do would be to pick one or the other.
Keyakinan
Yes I have full pass through now with a backup of all my data (for now). I think tomorrow I'm putting them in raidz1 For now I want to use PfSense and TrueNAS next to eachother and truenas with plex/*arr/ ha. But once when I upgrade my server I'm prob putting just truenas with virtualization. This is a good way to learn I must say, but complicated.
