For my TrueNAS machine I have a motherboard with 6x SATA ports (6Gbit) based on H97 intel chipset + SATA controller PCIe 1x with 2x SATA ports (6Gbit).
The added card is a cheap one I bought many years ago based on ASMedia ASM1062 - not sure how good and reliable it should be but I used it here and there and so far didn't have issues.
I need more ports (total of 12 ports, prefer to replace the controller card with 6 port card) and want to make sure to get a reliable controller which is not too expensive.
Most of the SATA controllers in Amazon are based on ASMedia chips (ASM1166 for example). for 6 port I think PCIe 4x is the right one to provide enough bandwidth.
how good and reliable those cards? do you have a recommendation on those cards?
Is it worth buying SAS controllers instead? (I saw here mostly LSI is recommended)
will SAS controller work out-of-the-box with sata drives and cables?
Please advise.
Please advise.
