Recommendations for 480GB NVMe SLOG / L2ARC config
averyfreeman
480GB Samsung SM953 NVMe SSD with PLP:
Just picked up this beaut today, it's an enterprise NVMe SSD with power loss protection. Check out the pics, you can see the honkin' capacitors on the front and back.
I was thinking of partitioning it and using somewhere between 8-24GB for the SLOG and the rest (460GB-ish) for an L2ARC. I'll be using it via PCIe passthrough with an 8TB mirror as an NFS datastore for VM storage (ESXi).
Any recommendations on how to configure it with my mirror?
SweetAndLow
Sweet'NASty
Freenas version, hardware specs and workflows? I doubt a slog or l2arc will just you at all and the l2arc will probably make it worse.
Chris Moore
@Stux did a good writeup on this very special case.
You should do a search.
I would link to it but I am on my phone and driving.
Chris Moore
Did you ever do this?
What were the steps you took to implement it?
What were your results?
HoneyBadger
actually does care
Administrator
Don't text and drive, you can't zfs rollback real life.
@OP, I'm curious to see the results as well if you implemented this. Another user was having issues with this same drive (in AIC form factor, though) not giving the expected throughput, you can see the benchmarks at the end of the SLOG thread linked in my signature:
https://forums.freenas.org/index.ph...inding-the-best-slog.63521/page-4#post-482724
Stux
