Random kernel Error - Destination address delete failed
Ryan Allen
Anyone know how to stop this error or even what this is?
I've googled it and keep getting a run around.
Ryan Allen
Sorry, should have put more info in that.
I'm running the latest version.
I can still access everything that i know of but I just want to make sure something isn't going on that will lead to bad things soon
Ryan Allen
What's the full output of ifconfig (within code tags)?
% ifconfig
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
ether 0c:c4:7a:9a:a3:b8
hwaddr 0c:c4:7a:9a:a3:b8
inet 10.70.10.3 netmask 0xffffff00 broadcast 10.70.10.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether 0c:c4:7a:9a:a3:b9
hwaddr 0c:c4:7a:9a:a3:b9
status: no carrier
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
groups: lo
ether 02:0d:aa:99:a7:00
nd6 options=1<PERFORMNUD>
groups: bridge
member: vnet0:8 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
member: vnet0:6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
vnet0:6: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: plex-plexpass as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:30:63:77
hwaddr 02:9c:d0:00:05:0a
status: active
groups: epair
vnet0:8: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: rslsync as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:51:f4:ac
hwaddr 02:9c:d0:00:06:0a
status: active
groups: epair
