thepixelgeek
- Jan 21, 2016
Last night, I reinstalled Plex jail. All the machines (tv, mac, win) connected fine and were able to play a movie.
Early this morning, the TV and Macbook did not have a connection to the server.
I downloaded the Plex client for Macbook, but it too failed to connect.
Edit: After checking Macbook connection again, an hour later, it reconnected.
Edit: 30mins later, the Mackbook lost connection again.
Edit: An hour or so later, the Macbook connected again.
TV still has no connection to the Plex server. I tried wired and wireless connections. No luck.
Edit: After a while it reconnected.
Windows machine is the only machine that stays connected to the Plex server.
All machines have 192.168.4.x.
Plex server is 192.168.4.x
Log:
Daily security output:
"CONFIG_VERSION": "14.1",
"allow_chflags": "0",
"allow_mlock": "0",
"allow_mount": "0",
"allow_mount_devfs": "0",
"allow_mount_nullfs": "0",
"allow_mount_procfs": "0",
"allow_mount_tmpfs": "0",
"allow_mount_zfs": "0",
"allow_quotas": "0",
"allow_raw_sockets": "1",
"allow_set_hostname": "1",
"allow_socket_af": "0",
"allow_sysvipc": "0",
"allow_tun": "0",
"available": "readonly",
"basejail": "no",
"boot": "on",
"bpf": "yes",
"children_max": "0",
"cloned_release": "11.3-RELEASE",
"comment": "none",
"compression": "lz4",
"compressratio": "readonly",
"coredumpsize": "off",
"count": "1",
"cpuset": "off",
"cputime": "off",
"datasize": "off",
"dedup": "off",
"defaultrouter": "192.168.4.1",
"defaultrouter6": "none",
"depends": "none",
"devfs_ruleset": "4",
"dhcp": "on",
"enforce_statfs": "2",
"exec_clean": "1",
"exec_fib": "0",
"exec_jail_user": "root",
"exec_poststart": "/usr/bin/true",
"exec_poststop": "/usr/bin/true",
"exec_prestart": "/usr/bin/true",
"exec_prestop": "/usr/bin/true",
"exec_start": "/bin/sh /etc/rc",
"exec_stop": "/bin/sh /etc/rc.shutdown",
"exec_system_jail_user": "0",
"exec_system_user": "root",
"exec_timeout": "60",
"host_domainname": "none",
"host_hostname": "plex",
"host_hostuuid": "plex",
"host_time": "yes",
"hostid": "00000000-0000-0000-0000-0CC47A8665C4",
"hostid_strict_check": "off",
"interfaces": "vnet0:bridge0",
"ip4": "new",
"ip4_addr": "igb0|192.168.4.97/24",
"ip4_saddrsel": "1",
"ip6": "new",
"ip6_addr": "none",
"ip6_saddrsel": "1",
"jail_zfs": "off",
"jail_zfs_dataset": "iocage/jails/plex/data",
"jail_zfs_mountpoint": "none",
"last_started": "2020-01-21 02:27:27",
"login_flags": "-f root",
"mac_prefix": "0cc47a",
"maxproc": "off",
"memorylocked": "off",
"memoryuse": "off",
"mount_devfs": "1",
"mount_fdescfs": "1",
"mount_linprocfs": "0",
"mount_procfs": "0",
"mountpoint": "readonly",
"msgqqueued": "off",
"msgqsize": "off",
"nmsgq": "off",
"notes": "none",
"nsemop": "off",
"nshm": "off",
"nthr": "off",
"openfiles": "off",
"origin": "readonly",
"owner": "root",
"pcpu": "off",
"priority": "99",
"pseudoterminals": "off",
"quota": "none",
"release": "11.3-RELEASE-p5",
"reservation": "none",
"resolver": "/etc/resolv.conf",
"rlimits": "off",
"securelevel": "2",
"shmsize": "off",
"stacksize": "off",
"stop_timeout": "30",
"swapuse": "off",
"sync_state": "none",
"sync_target": "none",
"sync_tgt_zpool": "none",
"sysvmsg": "new",
"sysvsem": "new",
"sysvshm": "new",
"template": "no",
"type": "jail",
"used": "readonly",
"vmemoryuse": "off",
"vnet": "on",
"vnet0_mac": "0ccxxxxxx09 0ccxxxxfa0a",
"vnet1_mac": "none",
"vnet2_mac": "none",
"vnet3_mac": "none",
"vnet_default_interface": "auto",
"vnet_interfaces": "none",
"wallclock": "off"
}Log:
Jan 20 17:03:32 plex newsyslog[31263]: logfile first created Jan 20 17:03:32 plex syslogd: kernel boot file is /boot/kernel/kernel Jan 20 17:03:40 plex pkg-static: pkg-1.12.0 installed Jan 20 17:03:41 plex pkg-static: pkg reinstalled: 1.12.0 -> 1.12.0 Jan 20 17:03:53 plex pkg: plexmediaserver-plexpass-1.18.3.2129 installed Jan 20 17:03:54 plex pkg: ca_root_nss-3.49.1 installed Jan 21 01:03:54 plex dhclient[30960]: connection closed Jan 21 01:03:54 plex dhclient[30960]: exiting. Jan 20 17:03:54 plex syslogd: exiting on signal 15 Jan 20 17:04:08 plex syslogd: kernel boot file is /boot/kernel/kernel Jan 20 17:19:49 plex pkg: plexmediaserver-plexpass upgraded: 1.18.3.2129 -> 1.18.4.2171 Jan 20 17:20:17 plex dhclient[31758]: connection closed Jan 20 17:20:17 plex dhclient[31758]: exiting. Jan 20 17:20:17 plex syslogd: exiting on signal 15 Jan 20 17:20:34 plex syslogd: kernel boot file is /boot/kernel/kernel Jan 20 18:27:17 plex dhclient[38874]: connection closed Jan 20 18:27:17 plex dhclient[38874]: exiting. Jan 20 18:27:17 plex syslogd: exiting on signal 15 Jan 20 18:27:27 plex syslogd: kernel boot file is /boot/kernel/kernel
> igb0: link state changed to DOWN > igb0: link state changed to UP > in6_purgeaddr: err=65, destination address delete failed > igb0: link state changed to DOWN > igb0: link state changed to UP > igb0: link state changed to DOWN > igb0: link state changed to UP > arp: 192.168.4.251 moved from 40:6c:8f:2b:d6:2d to 7c:c3:a1:b1:0d:2e on igb0 > epair0a: Ethernet address: 02:66:d0:00:05:0a > epair0b: Ethernet address: 02:66:d0:00:06:0b > epair0a: link state changed to UP > epair0b: link state changed to UP > epair0a: changing name to 'vnet0:50' > igb0: link state changed to DOWN > vnet0:50: promiscuous mode enabled > igb0: link state changed to UP > in6_purgeaddr: err=65, destination address delete failed > vnet0:50: link state changed to DOWN > epair0b: link state changed to DOWN > igb0: link state changed to DOWN > igb0: link state changed to UP > epair0a: Ethernet address: 02:66:d0:00:05:0a > epair0b: Ethernet address: 02:66:d0:00:06:0b > epair0a: link state changed to UP > epair0b: link state changed to UP > epair0a: changing name to 'vnet0:51' > igb0: link state changed to DOWN > vnet0:51: promiscuous mode enabled > igb0: link state changed to UP > in6_purgeaddr: err=65, destination address delete failed > vnet0:51: link state changed to DOWN > epair0b: link state changed to DOWN > igb0: link state changed to DOWN > igb0: link state changed to UP > in6_purgeaddr: err=65, destination address delete failed > in6_purgeaddr: err=65, destination address delete failed > arp: 192.168.4.251 moved from 40:6c:8f:2b:d6:2d to 7c:c3:a1:b1:0d:2e on igb0 > arp: 192.168.4.251 moved from 7c:c3:a1:b1:0d:2e to 40:6c:8f:2b:d6:2d on igb0 > epair0a: Ethernet address: 02:66:d0:00:05:0a > epair0b: Ethernet address: 02:66:d0:00:06:0b > epair0a: link state changed to UP > epair0b: link state changed to UP > epair0a: changing name to 'vnet0:56' > igb0: link state changed to DOWN > vnet0:56: promiscuous mode enabled > igb0: link state changed to UP > vnet0:56: link state changed to DOWN > epair0b: link state changed to DOWN > igb0: link state changed to DOWN > igb0: link state changed to UP > epair0a: Ethernet address: 02:66:d0:00:05:0a > epair0b: Ethernet address: 02:66:d0:00:06:0b > epair0a: link state changed to UP > epair0b: link state changed to UP > epair0a: changing name to 'vnet0:57' > igb0: link state changed to DOWN > vnet0:57: promiscuous mode enabled > igb0: link state changed to UP > in6_purgeaddr: err=65, destination address delete failed > vnet0:57: link state changed to DOWN > epair0b: link state changed to DOWN > igb0: link state changed to DOWN > igb0: link state changed to UP > epair0a: Ethernet address: 02:66:d0:00:05:0a > epair0b: Ethernet address: 02:66:d0:00:06:0b > epair0a: link state changed to UP > epair0b: link state changed to UP > epair0a: changing name to 'vnet0:58' > igb0: link state changed to DOWN > vnet0:58: promiscuous mode enabled > igb0: link state changed to UP > in6_purgeaddr: err=65, destination address delete failed > vnet0:58: link state changed to DOWN > epair0b: link state changed to DOWN > igb0: link state changed to DOWN > igb0: link state changed to UP > epair0a: Ethernet address: 02:66:d0:00:05:0a > epair0b: Ethernet address: 02:66:d0:00:06:0b > epair0a: link state changed to UP > epair0b: link state changed to UP > epair0a: changing name to 'vnet0:59' > igb0: link state changed to DOWN > vnet0:59: promiscuous mode enabled > igb0: link state changed to UP > in6_purgeaddr: err=65, destination address delete failed
