RAID Controller Card info?
yanni
Hi
I need to replace the raid controller card battery.
where i can see in the TrueNAS gui or in the shell command line
the raid controller card version without to do a restart to the server?
No, you need to stop using a RAID controller. See:
Ignoring that, how would you expect anyone to be able to give you an answer without identifying the controller you're using? I don't know if it'd be possible at all, but it certainly won't be possible without knowing what the controller is.
Patrick M. Hausen
cat /var/run/dmesg.boot should give you some information about brand, chipset, etc. If that is enough to identify the model, as always, depends.
yanni
Thank you, the model is PowerEdge 2900 and the Service Tag: 8FTP54J Link
I don't know if the RAID Controller is PERC 5/E or Dell SAS 5/i or Dell PERC 6/i or Dell PERC 5/i
Patrick M. Hausen
Then you will probably have to open up the case and have a look. Or ask Dell with the serial number at hand.
