Hardware Raid to ZFS migration
Engl_ish
I been using Windows 10 as Home server, so I have 2 group hardware Raid6 setup.
I would like to install TrueNAS, my question is will it see my hardware raid volume on TureNAS?
because I want to create ZFS(From group A) then copy all data from hardware Raid(From group B)
as now both raid A and B are same raid controller but, I separate it put group A to HBA card, eventually both in HBA card for ZFS.
Thanks in advance hoping my grammar was not too bad to understand my English is my first language so I speak Engl-ish not English.
Supermicro
X9DRi-LN4+/X9DR3-LN4+
Processor Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz, 3001 Mhz, 10 Core(s), 20 Logical Processor(s)
Installed Physical Memory (RAM) 64.0 GB
Raid controller
Adaptec ASR72405
HBA card not install
Scharbag
I think you will need another computer to do this.
Heracles
It should see the hardware part of it but not the filesystem that is on top of it. Second and mostly : NEVER user hardware raid with TrueNAS, not even in JBOD mode. For that, see this post by @jgreco.
Transfert over the network between 2 computers will be the way to migrate your data, as proposed by @Scharbag.
