I am brand new to FreeNAS but am fascinated by the potential. I have my hardware specced out but before i actually make the purchase i had a few questions i'd like to have answered.
1. RAM - for the ZFS file system the tutorials recommend 8 GB of RAM. The motherboard i have specced out can support 16 GB of RAM. Would it be worth it to max it out at 16GB? what will the benefits be?
2. Storage - I plan on using a RAID-Z1 array. I have 4 6TB drives specced out. That should equate to 18TB of actual storage correct? 6*3=18 with the 4th drive being used for parity.
3. Configuration - do you see any problems with my specs? From what i gather this should be a pretty powerful solution that should last a while.
Case - SR30169T2-250 Chenbro compact server Chasis
http://www.tigerdirect.com/applicat...eywords=SR30169T2-250+Compact+Server+Chassis+
Motherboard - H97I-PLUS Asus H97
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8992468&CatId=8586
CPU - BX80646G3450 Intel Pentium G3450
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8947624&CatId=9758
RAM - KVR1333D3E9SK2/16G Kingston RAM 16GB
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8947673&CatId=11479
USB for the OS - SDCZ36-008G-B35 Sandisk 8gb Flash Drive
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=630605&CatId=2633
Storage - WD60EFRX WD Red 6TB drives (4 of them)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9149259&Sku=
Does any of this seem like overkill? Am i missing any critical parts?
Thanks in advance for any feedback
