KempelofDoom
 - Apr 11, 2014
I have a setup that seems to be giving me trouble.  Things have been fantastic for some time.  Only recently have I had issues with latency and I'm not sure where to begin.  Regardless if I'm using sshfs or samba, it can take upwards of 30~60 seconds before a folder will finally open.  I started off with a round of 8 3TB drives in RaidZ1, then added another round of 8 3TB drives in RaidZ1 and used it to expand the current pool.  I was down to about 200GB of free space when things started getting wonky.  I added another 8 4TB drives in RaidZ1 and used it to expand the pool.  Performance remained spotty and I figured that things were getting bad because I was running out of space.  So then I decided to upgrade from 8.3.1 to 9.2.1.3.  Now I have some issues with smb but performance is still spotty even over sshfs.I'm fairly unfamiliar with FreeBSD but I am comfortable with Linux.  Where can I start viewing logs and determine if it's the network adapter, the drive controllers, smb, smart, or something else?  Does anyone have a suggestion that would help me improve performance?  I have a separate plex server that scans this file server over smb and it will sometimes scan quickly and sometimes it will choke over and over.  Specs below.
Asus F2A85-M/CSM
A8-5600K
32GB RAM
16 x 3TB
8 x 4TB
ARC-1260
Another disc controller to make up for the 1 missing sata port the mobo has only 7
Appreciate any suggestions as I would like to make sure my baby is running like a top.
			Asus F2A85-M/CSM
A8-5600K
32GB RAM
16 x 3TB
8 x 4TB
ARC-1260
