Question about SMARTCTL and RAID CARD
BlazeStar
Hi guys,
I my server, I installed a RAID card because I didn't have enough SATA ports.
4 HDD are connected on the RAID card and treated as JBOD.
When I run the SMARTCTL command it doesn't recognize them:
~# smartctl -a /dev/mfisyspd0
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
/dev/mfisyspd0: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
~# smartctl -a -d ata /dev/mfisyspd0
Read Device Identity failed: Inappropriate ioctl for device
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
~# smartctl -a -d ata -T permissive /dev/mfisyspd0
Device Model:    [No Information Found]
Serial Number:    [No Information Found]
Firmware Version: [No Information Found]
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:  [No Information Found]
Local Time is:    Fri Jun 13 17:56:03 2014 EDT
SMART support is: Ambiguous - ATA IDENTIFY DEVICE words 82-83 don't show if SMART supported.
SMART support is: Ambiguous - ATA IDENTIFY DEVICE words 85-87 don't show if SMART is enabled.
From what I see, I fear SMART is not supported.
Any idea how I can make it so SMART recognizes the drives and supports them?
This is one of the reason that RAID cards aren't recommended for use with FreeNAS--the hot ticket seems to be the IBM M1015, which will give you 8 SATA ports. What card, though? It's possible there's a way to enable this.
What's the model? If it's based on an LSI 2008 SAS controller, flash it to IT mode.
Drk
yes the 1015s are great i have 2 of them may get another for my box. they cost about 75-100 on ebay. What card do you have?
You shouldn't as long as you didn't do hardware RAID. ;)
I don't know anyone that's reflashed that exact card. But if it's like the M1015 (rebranded LSI 9211) then it should be just fine.
indy
Do you have hard drives that already part of a pool routed through that card?
Afaik you cant just flash a raid-card to it-mode if that is the case.
BlazeStar
Hi guys,
So I finally flashed my card using this awesome tutorial:
https://forums.freenas.org/index.ph...80-raid-controller-model-lsi-sas9240-8i.8632/
Only problem I had: I have a UEFI BIOS and didn't have an older computer to flash the card.
Therefore I had to learn the UEFI shell commands and download the installer for EFI from LSI (at the time of writing this message : P20)
Anyhow now everything works!
For example, when I run SMARTCTL commands, now I get this:
smartctl -a /dev/da0
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p12 amd64] (local build)
Device Model:     WDC WD4003FZEX-00Z4SA0
Serial Number:    WD-WCC130832923
LU WWN Device Id: 5 0014ee 25e09ddae
Firmware Version: 01.01A01
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    7200 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Nov  7 13:23:22 2014 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (44040) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 476) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x7035)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   161   133   021    Pre-fail  Always       -       10916
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       48
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   094   094   000    Old_age   Always       -       4807
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       48
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       47
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   115   112   000    Old_age   Always       -       37
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
So now SMARTCTL see my drive !!!! HURRAY
However, I don't understand why it would say that:
Hi guys,
Only problem I had: I have a EFI BIOS and didn't have an older computer to flash the card.
Therefore I had to learn the EFI shell commands and download the installer for EFI from LSI (at the time of writing this message : P20)
                    been run.
                    command.
                    power-saving mode.
No Errors Logged
It's a newish drive and smartctl probably hasn't been updated in a while. Nothing to worry about.
You *do* need P16 firmware, though. Use the new flasher and the old image.
Where is the new software ?
Well, you just used it, I guess. I believe P16 didn't have a UEFI flasher yet, so you'd have to get the flasher from a later release.
Actually the UEFI flasher has been around for a while.. I think P9 or so.
gpsguy
Active Member
Now that you have it working, you'll want to run some short and long tests on the drives and schedule them to run in the future.
BlazeStar
Well I used everything from the post I linked, except for the UEFI installer, which I got from LSI website, and I used P20 (sas2flash.efi)
