qBittorent restarting every 3 minutes
It's called "resource limits", nowhere is it called "allocated".
looks like the problem is ram allocation.
But does this mean that those 4 GiB of "allocated" RAM will be unavailable for the ZFS ARC and/or the host system?
I always take someone's word as they wrote it. Hence, why I put "quotes" around the word "allocated", since it has a very specific meaning. :wink: Considering you can allocate RAM to a VM, I assumed the OP was referring to some new/unique feature in SCALE.
truecharts
I think the real issue of my post is the +3gb consumption. I compared the official version and it is using a bit less. good learning. thanks
The most likely issue is mistakes in your testing.
As both use the same container and mostly the same configuration for said container.
If you need any further help, please do reach out to our staff on discord.
nikkon
thanks for the support. I manage to get it right and fine tune it to my needs. appreciate the support and engagement :)
