andimattes
- Nov 2, 2023
I just wanted to install a custom docker app on my TrueNAS Scale 23.10.0.1
As I'm hosting my own registry (using the dockerregistry chart from truecharts) I added <nas-ip>/<image-name> as the url for the dockerfile. When deploying the container I get an error regarding the lack of HTTPS of my registry (which is true as it just runs on HTTP).
The exact error is the following:
This error is common since I had the same error when trying to push a docker image from my local computer to the registry. In general this error can be easily solved by adding to /etc/docker/daemon.json (as described here on stackoverflow)
Unfortunately I was not able to do the same on TrueNAS Scale. Does anyone else experienced the same and have a potential solution?
Thanks for every help in advance!
http: server gave HTTP response to HTTPS client
"insecure-registries" : [ "host-ip:5000" ]
