SOLVED Use Container Registry Other Than Docker Hub
HarryMuscle
Is it possible to use a container registry other than Docker Hub with the Launch Docker Image functionality in TrueNAS Scale? If not, is there another way to be able to access images stored on other registries, like for example the GitHub Container Registry?
Alternatively, any way to load a container image manually instead of downloading it automatically from a registry?
Thanks,
Harry
Where you specify the container, specify the full path/url. If none is specified, docker hub is assumed.
