Hi Folks
I rebooted my TrueNAS server. After this i am not able to access 5 out 6 windows shares. After some investigation i find the following
1. On TrueNAS there is no data corruption, the files systems are present and data is available and accessible
2. When go to the truenas web admin console and got Windows Shares, it lists all the shares
3. But for the 5 shares that i cant access if i click the 3 dots and access "Edit Share ACL" nothing happens, it just stays on the same screen. But for the one share that works and i can access doing this opens the "Share ACL" screen.
So i assume something has gone wrong with the Share ACL. How do i recover from this ?
EDIT: Ok found out the issue. Turns out i was trying to force the min protocol to be SMB2 and had put that value in one of the shares "Auxillary Parameters". Though it did not allow to save because it errored out it still was present in the config. Removing this solved the issue.
