Problem with login after update
MrJoki007
today i updated my Truenas from 12.0 U 2.1 to 12.0 U3.
After the update i had problems with booting.
Now i got that fixed but i cant log in anymore. Neither in the webinterface, nor over ssh and smb.
When i try to change my password over cli, i get this error: Screenshot attached
How can i fix this problem?
ThreeDee
did you check the box that says save password stuff when you did the upgrade?
ThreeDee
yes
Hakkyokuken
Hey there, I'm getting the same error. How did you go about downgrading without getting into the client? Just a fresh install of the old version and use a backup config?
MrJoki007
I plugged in monitor and keyboard directly into my machine.
When freenas is booted up you can select to go into console.
With the command beadm list you get a list with all available environments and you can activate the one before upgrade with beadm activate
