problem with ISCSI
dannyb78
Hi, I'm running FN8.0.2 release in a dedicated HW with Z68+i3 CPU with 4GB of RAM and just 2 mirrored Disks full ZFS.
I'm trying to enable an ISCSI target with "0" dimensioned (dynamic) extent.
When enabling ISCSI service I get this log.
What should I change in order to get ISCSI working? thanks
Dec 14 13:33:41 freenas freenas[1635]: Executing: /usr/sbin/service ix-istgt quietstart
Dec 14 13:33:42 freenas freenas[1635]: Executing: /usr/sbin/service istgt forcestop
Dec 14 13:33:42 freenas freenas: istgt not running? (check /var/run/istgt.pid).
Dec 14 13:33:42 freenas freenas[1635]: Executing: /usr/sbin/service istgt restart
Dec 14 13:33:42 freenas freenas: Starting istgt.
Dec 14 13:33:42 freenas freenas: istgt version 0.4 (20110928)
Dec 14 13:33:42 freenas istgt[5838]: istgt version 0.4 (20110928)
Dec 14 13:33:42 freenas freenas: normal mode
Dec 14 13:33:42 freenas istgt[5838]: normal mode
Dec 14 13:33:42 freenas freenas: istgt_lu.c:1653:istgt_lu_add_unit: ***ERROR*** LU1: LUN0: Auto size error (/mnt/backup1//VMWare/VMWareISCSI)
Dec 14 13:33:42 freenas istgt[5838]: istgt_lu.c:1653:istgt_lu_add_unit: ***ERROR*** LU1: LUN0: Auto size error (/mnt/backup1//VMWare/VMWareISCSI)
Dec 14 13:33:42 freenas freenas: istgt_lu.c:1954:istgt_lu_init: ***ERROR*** lu_add_unit() failed
Dec 14 13:33:42 freenas istgt[5838]: istgt_lu.c:1954:istgt_lu_init: ***ERROR*** lu_add_unit() failed
Dec 14 13:33:42 freenas freenas: istgt.c:1667:main: ***ERROR*** istgt_lu_init() failed
Dec 14 13:33:42 freenas istgt[5838]: istgt.c:1667:main: ***ERROR*** istgt_lu_init() failed
Dec 14 13:33:42 freenas root: /usr/local/etc/rc.d/istgt: WARNING: failed to start istgt
Dec 14 13:33:42 freenas freenas: /usr/local/etc/rc.d/istgt: WARNING: failed to start istgt
Dec 14 13:33:42 freenas freenas[1635]: Executing: /bin/pgrep -F /var/run/istgt.pid istgt
William Grzybowski
There is no such thing of "dynamic", you need to set the size, if the size is 0 that means the file should exists...
dannyb78
in old documentations "0" was for dynamic, or my bad english let me understand so.
Setting a size make it works
thanks
