Please note: "Path to the extent" is the full path to the extent file (including the extent filename), not just the path.
e.g. if your extent name is "iscsi1" located in "/mnt/pool0/iscsi" then the "Path to the extent" is "/mnt/pool0/iscsi/iscsi1", not just "/mnt/pool0/iscsi" as you might expect.
Otherwise, you might see this in your "/var/log/messages":
Jul 10 15:42:16 freenas freenas: istgt_lu.c:1714:istgt_lu_add_unit: ***ERROR*** LU1: no LUN
Jul 10 15:42:16 freenas istgt[9178]: istgt_lu.c:1714:istgt_lu_add_unit: ***ERROR*** LU1: no LUN
Jul 10 15:42:16 freenas freenas: istgt_lu.c:1863:istgt_lu_init: ***ERROR*** lu_add_unit() failed
Jul 10 15:42:16 freenas istgt[9178]: istgt_lu.c:1863:istgt_lu_init: ***ERROR*** lu_add_unit() failed
Jul 10 15:42:16 freenas freenas: istgt.c:1665:main: ***ERROR*** istgt_lu_init() failed
Jul 10 15:42:16 freenas istgt[9178]: istgt.c:1665:main: ***ERROR*** istgt_lu_init() failed
Jul 10 15:42:16 freenas root: /usr/local/etc/rc.d/istgt: WARNING: failed to start istgt
Jul 10 15:42:16 freenas freenas: /usr/local/etc/rc.d/istgt: WARNING: failed to start istgt
Jul 10 12:42:28 freenas freenas[1463]: Executing: /usr/sbin/service ix-istgt quietstart
Jul 10 12:42:28 freenas freenas[1463]: Executing: /usr/sbin/service istgt forcestop
