pseudoyams
- Mar 13, 2014
Hi All-
I have a FreeNAS 9.2.1.2 that I put together and attached to a esxi 5.1 host. Im using the FreeNAS device for storage for some VMs I replicate between sites. I upgraded to v9.2.1.2 recently and have found that as soon as data starts being written to the FreeNAS device, it stops responding and the datastore become unavailable to the esxi server. If I stop the replication job and then rescan it will reconnect to the esxi host.
I show this listed in messages:
Mar 13 11:42:49 FreeNAS-iscsi-01 istgt[2325]: istgt_iscsi.c:5270:worker_cleanup: ***WARNING*** force cleanup execute
Mar 13 11:42:49 FreeNAS-iscsi-01 istgt[2325]: istgt_lu_disk.c:5318:istgt_lu_disk_queue_start: ***WARNING*** transfer abort CmdSN=29889519
Mar 13 11:42:49 FreeNAS-iscsi-01 istgt[2325]: istgt_lu.c:3255:luworker: ***WARNING*** LU1: lu_disk_queue_start() aborted
Mar 13 11:42:49 FreeNAS-iscsi-01 last message repeated 11 times
Mar 13 11:42:49 FreeNAS-iscsi-01 istgt[2325]: istgt_iscsi.c:1261:istgt_iscsi_write_pdu_internal: ***ERROR*** writev() failed (errno=32,iqn.1998-01.com.vmware:esxi01-6320b62a,time=0)
Mar 13 11:42:49 FreeNAS-iscsi-01 last message repeated 7 times
Mar 13 11:42:49 FreeNAS-iscsi-01 istgt[2325]: istgt_iscsi.c:5414:sender: ***ERROR*** iscsi_write_pdu() failed on iqn.2011-03.local.kasd.istgt:FreeNAS-iscsi-01,t,0x0001(iqn.1998-01.com.vmware:esxi01-6320b62a,i,0x00023d000001)
Mar 13 11:42:49 FreeNAS-iscsi-01 istgt[2325]: Login from iqn.1998-01.com.vmware:esxi01-6320b62a (10.1.1.1) on iqn.2011-03.local.kasd.istgt:FreeNAS-iscsi-01 LU1 (10.1.1.100:3260,1), ISID=23d000001, TSIH=6, CID=0, HeaderDigest=off, DataDigest=off
Can somebody help me out with this? Not sure where to start with this.
Thanks.
Thanks.
