I run truenas scale as proxmox ve without problems - till now
I use raid-z in proxmox and forward the disk as scsi to truenas. There I use "single disks".
Now I extended the forwarded disk size in proxmox. Truenas scale does recognize this but expansion under the gui does not work:
- autoexpand is (and was always) on
- zpool list shows the EXPANDSZ cloumn with the correct values and using zpool online -e does not change anything....
any ideas?
using commandline does not work either:Fehler: Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 409, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 445, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1269, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1137, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/expand.py", line 46, in expand
raise CallError('Expand is not supported on this platform yet because of underlying ZFS issues.')
middlewared.service_exception.CallError: [EFAULT] Expand is not supported on this platform yet because of underlying ZFS issues.
any ideas?
