m0t0rh3ad
- Jul 13, 2020
Hello, I''m using TrueNAS-SCALE-20.12-ALPHA
The system shows me that one of the Disks has 60 read errors and 2 write errors. I made the faulted disk offline, removed it, and place a new one.
old disk sdn
new disk sdo
But I can't make Replace procedure:
Try to replace disk without force option:
Error Replacing Disk
[EINVAL] options.force: Disk is not clean, partitions were found.
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 372, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 408, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1021, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/replace_disk.py", line 81, in replace
raise verrors
middlewared.service_exception.ValidationErrors: [EINVAL] options.force: Disk is not clean, partitions were found.
With force option:
Could not replace disk.
await self.future
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/replace_disk.py", line 104, in replace
await self.middleware.call('disk.swaps_remove_disks', swap_disks)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1258, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1215, in _call
File "/usr/lib/python3/dist-packages/middlewared/service.py", line 44, in l_fn
return await fn(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/swap_remove.py", line 27, in swaps_remove_disks
return await self.swaps_remove_disks_unlocked(disks, options)
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/swap_remove.py", line 51, in swaps_remove_disks_unlocked
for mirror in await self.middleware.call('disk.get_swap_mirrors'):
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1226, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1130, in run_in_executor
File "/usr/lib/python3/dist-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1025, in nf
return f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/swap_mirror_linux.py", line 53, in get_swap_mirrors
with open(os.path.join('/sys/class/block', provider, 'partition'), 'r') as f:
FileNotFoundError: [Errno 2] No such file or directory: '/sys/class/block/sdn1/partition'
When I've tried to wipe disk I've got this:
Wipe Disk sdo
Please help
old disk sdn
new disk sdo
await self.future
raise verrors
With force option:
await self.future
Wipe Disk sdo
Please help
