Volume import fails (Scale22.02 RC-2)
rmont
I started having issues on boot. Boot process hangs 15 minutes on importing of ZFS devices.
I exported disks one by one to see if I could find one that was hanging the process.
Apparently I found the disk that hangs the import process.
When I try to import the disk back, I get the following error.
Error: concurrent.futures.process._RemoteTraceback:
  File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
    r = call_item.fn(*call_item.args, **call_item.kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 97, in main_worker
    res = MIDDLEWARE._run(*call_args)
  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 45, in _run
    return self._call(name, serviceobj, methodobj, args, job=job)
  File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 39, in _call
    return methodobj(*params)
  File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1273, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 367, in import_pool
    self.logger.error(
  File "libzfs.pyx", line 404, in libzfs.ZFS.__exit__
  File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 357, in import_pool
    raise CallError(f'Pool {name_or_guid} not found.', errno.ENOENT)
middlewared.service_exception.CallError: [ENOENT] Pool 11800105781617139803 not found.
The above exception was the direct cause of the following exception:
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 409, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 445, in __run_body
  File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1269, in nf
  File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1137, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 1504, in import_pool
    await self.middleware.call('zfs.pool.import_pool', pool['guid'], {
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1324, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1289, in _call
    return await self._call_worker(name, *prepared_call.args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1295, in _call_worker
    return await self.run_in_proc(main_worker, name, args, job)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1218, in run_in_proc
    return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1192, in run_in_executor
On the command line (zpool list) the disk is present. And I can navigate to the disk's directories.
But on the GUI, the disk does not show up.
I have already tried exporting again from command line, rebooting and importing via GUI. But same happens.
Thanks for helping
morganL
Captain Morgan
Administrator
Can you confirm there was no issue with RC1.2.. can you rollback?
rmont
I can't roll back to 1.2. I upgraded from Core to RC-2.
After the upgrade everything went smoothly. After a couple of days the server crashed and I started having these issues on boot.
