I am having trouble importing a pool from Truenas Core in Truenas Scale 21.02-ALPHA.1
I am running Truenas Scale as VM on vSphere with passthrough of SAS2008 based controllers.
The error message I get is:
[ENOENT] Pool 2491833529097242126 not found.
At commandline "zpool import 2491833529097242126" works fine.
Another pool from the same Truenas Core machine imported without issues.
Full error message:
Full error message:
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 94, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1003, in nf
return f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 388, in import_pool
self.logger.error(
File "libzfs.pyx", line 391, in libzfs.ZFS.__exit__
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 379, in import_pool
raise CallError(f'Pool {name_or_guid} not found.', errno.ENOENT)
middlewared.service_exception.CallError: [ENOENT] Pool 2491833529097242126 not found.
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 378, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 414, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 999, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 1420, in import_pool
await self.middleware.call('zfs.pool.import_pool', pool['guid'], {
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1266, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1231, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1237, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1164, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1138, in run_in_executor
