Hi
I created a 6 disk z2 vdev with low capacity disks and everything is working as expected.
Now, I've replaced all the disks with higher capacity ones, the Pool size hasn't increased.
If I select the 'Expand' option in the pool, I get an error stating this feature isn't supported (see below)
Is there any way to tell the vdev / pool to use all available space on the new drives ?
Thanks
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 382, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 418, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1182, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1092, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/expand.py", line 46, in expand
raise CallError('Expand is not supported on this platform yet because of underlying ZFS issues.')
middlewared.service_exception.CallError: [EFAULT] Expand is not supported on this platform yet because of underlying ZFS issues.
Thanks
await self.future
