jafin
- May 30, 2011
I am trying to destroy a pool, but receive the below error.
The pool is currently attempting a resilver.
(EDIT): Resilver is complete, error still occurs via the GUI.
* Is this expected?
* Is there any way to force destroy as there is no requirement for the resilver to complete?
* Is this expected?
[EFAULT] pool or dataset is busy The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 411, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 446, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1272, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1140, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 1601, in export await self.middleware.call('zfs.pool.delete', pool['name']) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1344, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1293, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/service.py", line 942, in delete rv = await self.middleware._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1301, in _call return await self._call_worker(name, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1307, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1222, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1205, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) middlewared.service_exception.CallError: [EFAULT] pool or dataset is busy
