vasiliinorris
- Sep 23, 2022
I've got 3 DAS.
DAS 1: 8x3TB
DAS 2: 7x3TB+1x4TB (needed to replace a dead 3TB drive, had only 4TB spares)
DAS 3: 8x4TB
Which would be the best way to utilize the storage?
Should I create one pool with 15x3TB in RAIDZ3 + one pool 9x4TB RAIDZ2, one pool 8x3TB RAIDZ1 + one pool 7x3TB RAIDZ1 + one pool 8x4TB RAIDZ1 or should I somehow combine all of the pools together? Or would you suggest some other variant?
The data stored are media files, photos, videos, movies, TV series etc., so I don't need great IO but do need good sequential read/write speeds to fully utilize the 10 Gbit connection.
DAS 1: 8x3TB
DAS 3: 8x4TB
