Pool Status Unhealthy Literally No Drive Errors
jpcapone
Ok in my TrueNAS dashboard the Pool Status reports as being unhealthy while everything else is green.
But there are no errors
Everything is functioning nominally but it is kind of annoying. I just rebuilt my TrueNAS system - which used to be virtual - with ECC RAM because I was experiencing rando read/write/checksum errors on disks that were brand new. So now no errors but still unhealthy. Any suggestions?
Samuel Tai
Run zpool status -v <name of your pool>. It will describe what it's unhappy about.
jpcapone
Thanks for that. This is what I get:
/var/db/system/rrd-1e9984bcf13340bcb68bc263ecb0a902/localhost/cpu-1/percent-system.rrd
/var/db/system/rrd-1e9984bcf13340bcb68bc263ecb0a902/localhost/cpu-3/percent-system.rrd
Any suggestions on next steps? I would delete them but I don't think that would resolve the issue.
Samuel Tai
That's graph data for the system graphs. You don't need to delete them. Just switch the system dataset in System->System Dataset back to your boot pool. Then scrub your data pool. You may need to scrub a couple of times to clear the unhealthy status. Then move the system dataset back.
jpcapone
Ok I moved the System Dataset back to boot and I ran the scrub process quite a few times and I even rebooted but the pool still reports unhealthy and the status -v still shows the same problematic files. Do I need to wait until it reports healthy before I switch the System Dataset back? Any other suggestions? Here is a screener showing that I did switch the option you mentioned.
jpcapone
Ok I have followed your directions and I have been scrubbing the pool every day since my original post and I am still coming up with an unhealthy pool. Any other suggestions?
SweetAndLow
Sweet'NASty
You never actually ran the zpool status -v command that was asked of you. Please do that
jpcapone
Maybe I am missing something but I posted the results of the zpool status -v on February 1, 2021 and Samuel Tai responded to it on the same day. I ran another one and the full results below:
        DeadPool                                        ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/1b9f87fe-4ecd-11eb-b807-005056ab46b3  ONLINE       0     0     8
            gptid/05bc6ea1-5c57-11eb-8d6f-005056ab46b3  ONLINE       0     0     8
            gptid/df60cc1b-56ec-11eb-8b64-005056ab46b3  ONLINE       0     0     8
            gptid/2464e446-4ecd-11eb-b807-005056ab46b3  ONLINE       0     0     8
            gptid/212f21fa-4ecd-11eb-b807-005056ab46b3  ONLINE       0     0     8
            gptid/29a80c52-4ecd-11eb-b807-005056ab46b3  ONLINE       0     0     8
            gptid/effe0a3e-5fff-11eb-aa71-005056ab46b3  ONLINE       0     0     8
            gptid/99c6547d-521a-11eb-a710-005056ab46b3  ONLINE       0     0     8
        DeadPool/.system/rrd-1e9984bcf13340bcb68bc263ecb0a902:/localhost/cpu-1/percent-system.rrd
        DeadPool/.system/rrd-1e9984bcf13340bcb68bc263ecb0a902:/localhost/cpu-3/percent-system.rrd
root@freenas[~]#
Alecmascot
There are the drive errors....
I now think we need full specs of your system as per the forum rules.
SweetAndLow
Sweet'NASty
root@freenas[~]#
You never posted this. Can you now post the smartctl -a info for each disk? Looks like every disk in your system has checksum errors.
jpcapone
Sorry for the confusion.......
jpcapone
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Any ideas or recommendations regarding my issue?
SweetAndLow
Sweet'NASty
no clue that link doesn't work. Can you just post the output using [CODE ] tags?
jpcapone
Thanks for getting back to me. When i do that it says I am over the character limit.
jpcapone
root@freenas[~]# smartctl -a /dev/da0
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p2 amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Toshiba X300
Device Model:     TOSHIBA HDWE140
Serial Number:    Y043K5ZFFBRG
LU WWN Device Id: 5 000039 a6b8001b3
Firmware Version: FP1R
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Feb  9 15:52:12 2021 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  120) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 487) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   050    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   050    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       5942
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       979
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       2456
  7 Seek_Error_Rate         0x000b   100   100   050    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   100   100   050    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       945
 10 Spin_Retry_Count        0x0033   119   100   030    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       979
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       17
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       969
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1056
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       27 (Min/Max 17/47)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       146
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   253   000    Old_age   Always       -       0
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       0
222 Loaded_Hours            0x0032   098   098   000    Old_age   Always       -       870
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
224 Load_Friction           0x0022   100   100   000    Old_age   Always       -       0
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       556
240 Head_Flying_Hours       0x0001   100   100   001    Pre-fail  Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%       357         -
jpcapone
root@freenas[~]# smartctl -a /dev/da1
Model Family:     Western Digital Red Pro
Device Model:     WDC WD4003FFBX-68MU3N0
Serial Number:    V1HHZNMG
LU WWN Device Id: 5 000cca 0bcd55c2f
Firmware Version: 83.00A83
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Feb  9 15:54:07 2021 EST
                                        been run.
data collection:                (   87) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 420) minutes.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   133   133   054    Old_age   Offline      -       93
  3 Spin_Up_Time            0x0007   134   134   024    Pre-fail  Always       -       328 (Average 301)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       42
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   128   128   020    Old_age   Offline      -       18
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       890
 10 Spin_Retry_Count        0x0012   100   100   060    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       42
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       79
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       79
194 Temperature_Celsius     0x0002   214   214   000    Old_age   Always       -       28 (Min/Max 16/42)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
jpcapone
root@freenas[~]# smartctl -a /dev/da3
Serial Number:    Y03AK70SFBRG
LU WWN Device Id: 5 000039 a6bb80193
Local Time is:    Tue Feb  9 15:57:13 2021 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 475) minutes.
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       456
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       64
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       810
 10 Spin_Retry_Count        0x0033   101   100   030    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       64
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       112
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       56
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       92
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       26 (Min/Max 15/44)
222 Loaded_Hours            0x0032   098   098   000    Old_age   Always       -       805
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       559
No Errors Logged
root@freenas[~]# smartctl -a /dev/da4
Serial Number:    Y03AK70NFBRG
LU WWN Device Id: 5 000039 a6bb8018e
Local Time is:    Tue Feb  9 15:58:27 2021 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 484) minutes.
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       5782
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       40
 10 Spin_Retry_Count        0x0033   100   100   030    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       40
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       52
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       32
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       61
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       29 (Min/Max 17/44)
222 Loaded_Hours            0x0032   098   098   000    Old_age   Always       -       806
No Errors Logged
root@freenas[~]# smartctl -a /dev/da5
Serial Number:    V1J3ME5G
LU WWN Device Id: 5 000cca 0bcddd50a
Local Time is:    Tue Feb  9 15:59:06 2021 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 452) minutes.
  2 Throughput_Performance  0x0004   132   132   054    Old_age   Offline      -       96
  3 Spin_Up_Time            0x0007   140   140   024    Pre-fail  Always       -       305 (Average 300)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       36
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       727
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       36
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       68
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       68
194 Temperature_Celsius     0x0002   206   206   000    Old_age   Always       -       29 (Min/Max 14/40)
No Errors Logged
jpcapone
root@freenas[~]# smartctl -a /dev/da6
Serial Number:    VBGHXM6F
LU WWN Device Id: 5 000cca 095c73d00
Local Time is:    Tue Feb  9 15:59:48 2021 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 466) minutes.
  3 Spin_Up_Time            0x0007   154   154   024    Pre-fail  Always       -       399 (Average 386)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       46
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       606
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       46
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       100
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       100
194 Temperature_Celsius     0x0002   206   206   000    Old_age   Always       -       29 (Min/Max 17/41)
No Errors Logged
root@freenas[~]# smartctl -a /dev/da7
Serial Number:    V1J26S3H
LU WWN Device Id: 5 000cca 0bcdd3112
Local Time is:    Tue Feb  9 16:00:28 2021 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 433) minutes.
  2 Throughput_Performance  0x0004   133   133   054    Old_age   Offline      -       92
  3 Spin_Up_Time            0x0007   140   140   024    Pre-fail  Always       -       311 (Average 296)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       29
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       409
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       29
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       72
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       72
194 Temperature_Celsius     0x0002   200   200   000    Old_age   Always       -       30 (Min/Max 17/38)
No Errors Logged
If Selective self-test is pending on power-up, resume after 0 minute dela
SweetAndLow
Sweet'NASty
Only da0 has ever had a self test run on it. I suggest running a long test on all drives and a short test on all drives.
These also look fairly new, did you do any burn in testing?
SweetAndLow
Sweet'NASty
You need to post all your system hardware specs also. Read the forum rules.
