Hi all,
I have a trueNAS Scale system as per below
- Asrock Z77 Pro4-M
 - Intel(R) Core(TM) i5-3550
 - 16GB RAM
 - 2 ZFS Arrays
 - 1 at 4x2TB and 1 mirrored 2X16TB
 pool: Mirror1
 state: ONLINE
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
  scan: scrub repaired 0B in 00:07:05 with 15 errors on Thu Oct 13 16:44:14 2022
        NAME                                      STATE     READ WRITE CKSUM
        Mirror1                                   ONLINE       0     0     0
          mirror-0                                ONLINE       0     0     0
            4bd33165-4513-4166-a5ac-dd3efddc946d  ONLINE       4     0  128K
            8cb65a36-33ef-4fd8-8919-1feb12a6a022  ONLINE       1     2  128K
        Mirror1/ix-applications/docker/2590635008c388fcc443cf2535076bfc8206baf27fd5e2dbadc2847eb6a477b1:<0x0>
        Mirror1/ix-applications/docker:<0x633>
        Mirror1/ix-applications/docker:<0x634>
        /mnt/Mirror1/ix-applications/docker/containers/e879fa17d1b13ffaca155733709516793b95fda5f9ba3089805400dce6b89d9f
        /mnt/Mirror1/ix-applications/docker/containerd/daemon/io.containerd.runtime.v2.task/moby
        /var/lib/kubelet/pods/1a1e36d1-61c4-4b72-be06-933bc64d43c3/containers/csi-snapshotter
        /mnt/Mirror1/ix-applications/catalogs/github_com_truecharts_catalog_main/.git/objects/pack
        <0xffffffffffffffff>:<0x596>
  pool: Pool1
 state: ONLINE
  scan: scrub repaired 0B in 13:59:14 with 0 errors on Sun Sep 18 14:00:49 2022
        Pool1                                     ONLINE       0     0     0
          raidz1-0                                ONLINE       0     0     0
            25c4e5a2-a13e-4fe3-bf61-6c5cf1ee0eb8  ONLINE       0     0     0
            8ba03677-7cd3-43b8-9664-2b8db64e697a  ONLINE       0     0     0
            a9f61bf1-6e53-4628-a696-0953019ceb97  ONLINE       0     0     0
errors: No known data errors
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:01:25 with 0 errors on Wed Oct 12 03:46:26 2022
          sdf3      ONLINE       0     0     0
