Pool Manager has no available after fresh installation
trojanx23
Pool Manager is not showing any available disks on running on PowerEdge R720xd running a RAID 10. There's about 32TB available but I'm unable to figure out what steps I'm missing to get the "Available Disks" to appear. I've installed both TrueNAS Core and now TrueNAS Scale I haven't had any luck with either software.
Samuel Tai
Look in the Disks screen to see if the disks appear at all. If they do, they may advertise they're already part of a pool. If not, you may need to wipe them to remove any lingering partition table. TrueNAS won't use disks with existing partitions as a safety feature.
