Alpha-Inc.
- Feb 15, 2021
Hello everybody,
I recently updated from FreeNAS 11.3 U5 to 12.0 U6 and the update went completely fine. But then I wanted to update my Plex Iocage with the command
and it gave me some errors:
Now when I want to update my Plex Plugin via the GUI I the message
Plex tells me, that there is an update but FreeNAS does not install an update but sometimes the update is available a little later. Therefore I want to know, if my iocage upgrade was successful (even tho it says the RELEASE branch does not exist) ?
Also - I read some comments on the internet where people said its better to install Plex manually within a jail. Is this true and if yes, how do you do this ?
iocage upgrade Plex --release 12.2-RELEASE
Snapshotting Plex...
Updating plugin INDEX...
Running upgrade...
Checking integrity... done (0 conflicting)
Deinstallation has been requested for the following 61 packages (of 0 packages in the universe):
Installed packages to be REMOVED:
aom: 3.2.0
argp-standalone: 1.3_4
ca_root_nss: 3.71
dav1d: 0.9.2
expat: 2.4.1
ffmpeg: 4.4.1,1
fontconfig: 2.13.94_1,1
freetype2: 2.11.0
fribidi: 1.0.11
gettext-runtime: 0.21
glib: 2.70.0_1,2
gmp: 6.2.1
gnutls: 3.6.16
graphite2: 1.3.14
harfbuzz: 3.0.0
indexinfo: 0.3.1
jpeg-turbo: 2.1.1
lame: 3.100_3
libX11: 1.7.2,1
libXau: 1.0.9
libXdmcp: 1.1.3
libXext: 1.3.4,1
libXfixes: 5.0.3_2
libass: 0.15.2
libdrm: 2.4.107_1,1
libepoll-shim: 0.0.20210418
libffi: 3.3_1
libiconv: 1.16
libidn2: 2.3.2
libogg: 1.3.5,4
libpciaccess: 0.16
libpthread-stubs: 0.4
libtasn1: 4.17.0
libtheora: 1.1.1_7
libudev-devd: 0.5.0
libunistring: 0.9.10_1
libv4l: 1.20.0_2
libva: 2.13.0
libvdpau: 1.4
libvorbis: 1.3.7_2,3
libvpx: 1.11.0
libx264: 0.163.3060
libxcb: 1.14_1
libxml2: 2.9.12
mpdecimal: 2.5.1
nettle: 3.7.3
opus: 1.3.1
p11-kit: 0.24.0
pciids: 20210930
pcre: 8.45
pkg: 1.17.3
plexmediaserver: 1.24.4.5081
png: 1.6.37_1
python38: 3.8.12_1
readline: 8.1.1
tpm-emulator: 0.7.4_2
trousers: 0.3.14_3
wayland: 1.19.0_1
x265: 3.4_1
xorgproto: 2021.4
xvid: 1.3.7,1
Number of packages to be removed: 61
The operation will free 572 MiB.
[Plex] [1/61] Deinstalling ffmpeg-4.4.1,1...
[Plex] [1/61] Deleting files for ffmpeg-4.4.1,1: .......... done
[Plex] [2/61] Deinstalling gnutls-3.6.16...
[Plex] [2/61] Deleting files for gnutls-3.6.16: .......... done
[Plex] [3/61] Deinstalling libass-0.15.2...
[Plex] [3/61] Deleting files for libass-0.15.2: .......... done
[Plex] [4/61] Deinstalling libva-2.13.0...
[Plex] [4/61] Deleting files for libva-2.13.0: .......... done
[Plex] [5/61] Deinstalling libvdpau-1.4...
pkg: Failed to execute lua script: [string "-- args: etc/vdpau_wrapper.cfg.sample..."]:12: attempt to call a nil value (field 'filecmp')
pkg: lua script failed
[Plex] [5/61] Deleting files for libvdpau-1.4: .......... done
[Plex] [6/61] Deinstalling harfbuzz-3.0.0...
[Plex] [6/61] Deleting files for harfbuzz-3.0.0: .......... done
[Plex] [7/61] Deinstalling libXext-1.3.4,1...
[Plex] [7/61] Deleting files for libXext-1.3.4,1: .......... done
[Plex] [8/61] Deinstalling libXfixes-5.0.3_2...
[Plex] [8/61] Deleting files for libXfixes-5.0.3_2: .......... done
[Plex] [9/61] Deinstalling p11-kit-0.24.0...
[Plex] [9/61] Deleting files for p11-kit-0.24.0: .......... done
[Plex] [10/61] Deinstalling glib-2.70.0_1,2...
[Plex] [10/61] Deleting files for glib-2.70.0_1,2: .......... done
[Plex] [11/61] Deinstalling libX11-1.7.2,1...
[Plex] [11/61] Deleting files for libX11-1.7.2,1: .......... done
[Plex] [12/61] Deinstalling trousers-0.3.14_3...
pkg: Failed to execute lua script: [string "-- args: etc/tcsd.conf.sample..."]:12: attempt to call a nil value (field 'filecmp')
[Plex] [12/61] Deleting files for trousers-0.3.14_3: .......... done
==> You should manually remove the "_tss" user.
==> You should manually remove the "_tss" group
[Plex] [13/61] Deinstalling fontconfig-2.13.94_1,1...
pkg: Failed to execute lua script: [string "-- args: etc/fonts/fonts.conf.sample..."]:12: attempt to call a nil value (field 'filecmp')
[Plex] [13/61] Deleting files for fontconfig-2.13.94_1,1: .......... done
[Plex] [14/61] Deinstalling libdrm-2.4.107_1,1...
[Plex] [14/61] Deleting files for libdrm-2.4.107_1,1: .......... done
[Plex] [15/61] Deinstalling libidn2-2.3.2...
[Plex] [15/61] Deleting files for libidn2-2.3.2: .......... done
[Plex] [16/61] Deinstalling libtheora-1.1.1_7...
[Plex] [16/61] Deleting files for libtheora-1.1.1_7: .......... done
[Plex] [17/61] Deinstalling libxcb-1.14_1...
[Plex] [17/61] Deleting files for libxcb-1.14_1: .......... done
[Plex] [18/61] Deinstalling nettle-3.7.3...
[Plex] [18/61] Deleting files for nettle-3.7.3: .......... done
[Plex] [19/61] Deinstalling python38-3.8.12_1...
[Plex] [19/61] Deleting files for python38-3.8.12_1: .......... done
[Plex] [20/61] Deinstalling tpm-emulator-0.7.4_2...
[Plex] [20/61] Deleting files for tpm-emulator-0.7.4_2: .......... done
[Plex] [21/61] Deinstalling wayland-1.19.0_1...
[Plex] [21/61] Deleting files for wayland-1.19.0_1: .......... done
[Plex] [22/61] Deinstalling freetype2-2.11.0...
[Plex] [22/61] Deleting files for freetype2-2.11.0: .......... done
[Plex] [23/61] Deinstalling gettext-runtime-0.21...
[Plex] [23/61] Deleting files for gettext-runtime-0.21: .......... done
[Plex] [24/61] Deinstalling gmp-6.2.1...
[Plex] [24/61] Deleting files for gmp-6.2.1: .......... done
[Plex] [25/61] Deinstalling libXdmcp-1.1.3...
[Plex] [25/61] Deleting files for libXdmcp-1.1.3: ......... done
[Plex] [26/61] Deinstalling libffi-3.3_1...
[Plex] [26/61] Deleting files for libffi-3.3_1: .......... done
[Plex] [27/61] Deinstalling libpciaccess-0.16...
[Plex] [27/61] Deleting files for libpciaccess-0.16: ......... done
[Plex] [28/61] Deinstalling libtasn1-4.17.0...
[Plex] [28/61] Deleting files for libtasn1-4.17.0: .......... done
[Plex] [29/61] Deinstalling libunistring-0.9.10_1...
[Plex] [29/61] Deleting files for libunistring-0.9.10_1: .......... done
[Plex] [30/61] Deinstalling libv4l-1.20.0_2...
[Plex] [30/61] Deleting files for libv4l-1.20.0_2: .......... done
[Plex] [31/61] Deinstalling libvorbis-1.3.7_2,3...
[Plex] [31/61] Deleting files for libvorbis-1.3.7_2,3: .......... done
[Plex] [32/61] Deinstalling readline-8.1.1...
[Plex] [32/61] Deleting files for readline-8.1.1: .......... done
[Plex] [33/61] Deinstalling aom-3.2.0...
[Plex] [33/61] Deleting files for aom-3.2.0: .......... done
[Plex] [34/61] Deinstalling argp-standalone-1.3_4...
[Plex] [34/61] Deleting files for argp-standalone-1.3_4: ......... done
[Plex] [35/61] Deinstalling ca_root_nss-3.71...
pkg: Failed to execute lua script: [string "-- args: etc/ssl/cert.pem.sample..."]:12: attempt to call a nil value (field 'filecmp')
[Plex] [35/61] Deleting files for ca_root_nss-3.71: ....... done
[Plex] [36/61] Deinstalling dav1d-0.9.2...
[Plex] [36/61] Deleting files for dav1d-0.9.2: .......... done
[Plex] [37/61] Deinstalling expat-2.4.1...
[Plex] [37/61] Deleting files for expat-2.4.1: .......... done
[Plex] [38/61] Deinstalling fribidi-1.0.11...
[Plex] [38/61] Deleting files for fribidi-1.0.11: .......... done
[Plex] [39/61] Deinstalling graphite2-1.3.14...
[Plex] [39/61] Deleting files for graphite2-1.3.14: .......... done
[Plex] [40/61] Deinstalling indexinfo-0.3.1...
[Plex] [40/61] Deleting files for indexinfo-0.3.1: .... done
[Plex] [41/61] Deinstalling jpeg-turbo-2.1.1...
[Plex] [41/61] Deleting files for jpeg-turbo-2.1.1: .......... done
[Plex] [42/61] Deinstalling lame-3.100_3...
[Plex] [42/61] Deleting files for lame-3.100_3: .......... done
[Plex] [43/61] Deinstalling libXau-1.0.9...
[Plex] [43/61] Deleting files for libXau-1.0.9: .......... done
[Plex] [44/61] Deinstalling libepoll-shim-0.0.20210418...
[Plex] [44/61] Deleting files for libepoll-shim-0.0.20210418: .......... done
[Plex] [45/61] Deinstalling libiconv-1.16...
[Plex] [45/61] Deleting files for libiconv-1.16: .......... done
[Plex] [46/61] Deinstalling libogg-1.3.5,4...
[Plex] [46/61] Deleting files for libogg-1.3.5,4: .......... done
[Plex] [47/61] Deinstalling libpthread-stubs-0.4...
[Plex] [47/61] Deleting files for libpthread-stubs-0.4: .... done
[Plex] [48/61] Deinstalling libudev-devd-0.5.0...
[Plex] [48/61] Deleting files for libudev-devd-0.5.0: ........ done
[Plex] [49/61] Deinstalling libvpx-1.11.0...
[Plex] [49/61] Deleting files for libvpx-1.11.0: .......... done
[Plex] [50/61] Deinstalling libx264-0.163.3060...
[Plex] [50/61] Deleting files for libx264-0.163.3060: ......... done
[Plex] [51/61] Deinstalling libxml2-2.9.12...
[Plex] [51/61] Deleting files for libxml2-2.9.12: .......... done
[Plex] [52/61] Deinstalling mpdecimal-2.5.1...
[Plex] [52/61] Deleting files for mpdecimal-2.5.1: .......... done
[Plex] [53/61] Deinstalling opus-1.3.1...
[Plex] [53/61] Deleting files for opus-1.3.1: .......... done
[Plex] [54/61] Deinstalling pciids-20210930...
[Plex] [54/61] Deleting files for pciids-20210930: ..... done
[Plex] [55/61] Deinstalling pcre-8.45...
[Plex] [55/61] Deleting files for pcre-8.45: .......... done
[Plex] [56/61] Deinstalling pkg-1.17.3...
pkg: Failed to execute lua script: [string "-- args: etc/pkg.conf.sample..."]:12: attempt to call a nil value (field 'filecmp')
[Plex] [56/61] Deleting files for pkg-1.17.3: .......... done
[Plex] [57/61] Deinstalling plexmediaserver-1.24.4.5081...
[Plex] [57/61] Deleting files for plexmediaserver-1.24.4.5081: .......... done
==> You should manually remove the "plex" user.
==> You should manually remove the "plex" group
[Plex] [58/61] Deinstalling png-1.6.37_1...
[Plex] [58/61] Deleting files for png-1.6.37_1: .......... done
[Plex] [59/61] Deinstalling x265-3.4_1...
[Plex] [59/61] Deleting files for x265-3.4_1: .......... done
[Plex] [60/61] Deinstalling xorgproto-2021.4...
[Plex] [60/61] Deleting files for xorgproto-2021.4: .......... done
[Plex] [61/61] Deinstalling xvid-1.3.7,1...
[Plex] [61/61] Deleting files for xvid-1.3.7,1: ........ done
Updating plugin artifact...
Cloning git repository
Branch 12.2-RELEASE does not exist at https://github.com/freenas/iocage-plugin-plexmediaserver.git!
Using "master" branch for plugin, this may not work with your RELEASE
Installing new pkgs...
Repo: iocage-plugins already exists, skipping!
Testing Host DNS response to pkg.FreeBSD.org
Testing Plex's SRV response to pkg.FreeBSD.org
Testing Plex's DNSSEC response to pkg.FreeBSD.org
Installing plugin packages:
- plexmediaserver...
- ffmpeg...
Plex successfully upgraded!Now when I want to update my Plex Plugin via the GUI I the message
Now when I want to update my Plex Plugin via the GUI I the message Error: [EFAULT] No updates available for Plex
