liming
Newbie
- Nov 20, 2020
Upgrade Freenas 11.3 to TrureNAS 12.2, the system is working well.
Try to upgrade nextcloud jail, follow those steps
1. iocage fetch (choose 12.2-RELEASE)
2. iocage upgrade -r 12.2-RELEASE nextcloud
got those logs as below and Nextcloud service show Internal Server Error
Snapshotting nextcloud...
Updating plugin INDEX...
Running upgrade...
Updating plugin artifact...
Branch 12.2-RELEASE does not exist at https://github.com/freenas/iocage-plugin-nextcloud.git!
Using "master" branch for plugin, this may not work with your RELEASE
Removing old pkgs...
Checking integrity... done (0 conflicting)
Deinstallation has been requested for the following 118 packages (of 0 packages in the universe):
Installed packages to be REMOVED:
ImageMagick7-nox11: 7.0.10.24_1
avahi-app: 0.7_3
bash: 5.0.18_3
bash-completion: 2.11,2
ca_root_nss: 3.58
cups: 2.3.3_1
curl: 7.73.0
cyrus-sasl: 2.1.27_1
dbus: 1.12.20_3
dbus-glib: 0.110
expat: 2.2.8
fftw3: 3.3.8_6
fontconfig: 2.13.92_2,1
freetype2: 2.10.4
gdbm: 1.18.1_1
gettext-runtime: 0.21
ghostscript9-agpl-base: 9.52_11
giflib: 5.2.1
glib: 2.66.2,1
gmp: 6.2.0
gnome_subr: 1.0
gnutls: 3.6.15
gobject-introspection: 1.66.1,1
groff: 1.22.4_3
gsfonts: 8.11_8
icu: 68.1,1
indexinfo: 0.3.1
jbig2dec: 0.19
jbigkit: 2.1_1
jpeg-turbo: 2.0.5
lcms2: 2.11_1
libICE: 1.0.10,1
libSM: 1.2.3,1
libX11: 1.6.12,1
libXau: 1.0.9
libXdmcp: 1.1.3
libargon2: 20190702
libdaemon: 0.14_1
libedit: 3.1.20191231,1
libevent: 2.1.12
libffi: 3.3_1
libgcrypt: 1.8.7
libgd: 2.3.0,1
libgpg-error: 1.39
libiconv: 1.16
libidn: 1.35
libidn2: 2.3.0_1
liblqr-1: 0.4.2
libltdl: 2.4.6
liblz4: 1.9.2_1,1
libnghttp2: 1.41.0
libpaper: 1.1.24.4
libpthread-stubs: 0.4
libraw: 0.19.5
libtasn1: 4.16.0
libunistring: 0.9.10_1
libwmf-nox11: 0.2.8.4_15
libxcb: 1.14_1
libxml2: 2.9.10_1
libxslt: 1.1.34_1
libzip: 1.5.2
mysql57-client: 5.7.32
mysql57-server: 5.7.32
nettle: 3.6
nextcloud-php74: 20.0.1
nginx: 1.18.0_30,2
oniguruma: 6.9.6
openjpeg: 2.3.1
openldap-client: 2.4.51
p11-kit: 0.23.21
pcre: 8.44
pcre2: 10.35
perl5: 5.32.0
php74: 7.4.12
php74-bcmath: 7.4.12
php74-bz2: 7.4.12
php74-ctype: 7.4.12
php74-curl: 7.4.12
php74-dom: 7.4.12
php74-exif: 7.4.12
php74-fileinfo: 7.4.12
php74-filter: 7.4.12
php74-gd: 7.4.12
php74-gmp: 7.4.12
php74-iconv: 7.4.12
php74-intl: 7.4.12_1
php74-json: 7.4.12
php74-ldap: 7.4.12
php74-mbstring: 7.4.12
php74-opcache: 7.4.12
php74-openssl: 7.4.12
php74-pdo: 7.4.12
php74-pdo_mysql: 7.4.12
php74-pecl-APCu: 5.1.19
php74-pecl-imagick-im7: 3.4.4_2
php74-posix: 7.4.12
php74-session: 7.4.12
php74-simplexml: 7.4.12
php74-xml: 7.4.12
php74-xmlreader: 7.4.12
php74-xmlwriter: 7.4.12
php74-xsl: 7.4.12
php74-zip: 7.4.12
php74-zlib: 7.4.12
pkg: 1.15.10
pkgconf: 1.7.3,1
png: 1.6.37
poppler-data: 0.4.10
protobuf: 3.13.0,1
psutils: 1.17_5
python37: 3.7.9_1
readline: 8.0.4
tiff: 4.1.0
tpm-emulator: 0.7.4_2
trousers: 0.3.14_3
uchardet: 0.0.7
webp: 1.1.0
xorgproto: 2020.1
Number of packages to be removed: 118
The operation will free 1 GiB.
[nextcloud] [1/118] Deinstalling php74-pecl-imagick-im7-3.4.4_2...
[nextcloud] [1/118] Deleting files for php74-pecl-imagick-im7-3.4.4_2: .......... done
[nextcloud] [2/118] Deinstalling ImageMagick7-nox11-7.0.10.24_1...
pkg: Failed to execute lua script: [string "args = {}..."]:11: attempt to call a nil value (field 'filecmp')
pkg: lua script failed
[nextcloud] [2/118] Deleting files for ImageMagick7-nox11-7.0.10.24_1: .......... done
[nextcloud] [3/118] Deinstalling ghostscript9-agpl-base-9.52_11...
[nextcloud] [3/118] Deleting files for ghostscript9-agpl-base-9.52_11: .......... done
[nextcloud] [4/118] Deinstalling cups-2.3.3_1...
[nextcloud] [4/118] Deleting files for cups-2.3.3_1: .......... done
==> You should manually remove the "cups" user.
==> You should manually remove the "cups" group
[nextcloud] [5/118] Deinstalling avahi-app-0.7_3...
[nextcloud] [5/118] Deleting files for avahi-app-0.7_3: .......... done
==> You should manually remove the "avahi" user.
==> You should manually remove the "avahi" group
[nextcloud] [6/118] Deinstalling nextcloud-php74-20.0.1...
TL;DR
[nextcloud] [118/118] Deinstalling xorgproto-2020.1...
[nextcloud] [118/118] Deleting files for xorgproto-2020.1: .......... done
Installing new pkgs...
Testing Host DNS response to pkg.FreeBSD.org
Testing nextcloud's SRV response to pkg.FreeBSD.org
Testing nextcloud's DNSSEC response to pkg.FreeBSD.org
Installing plugin packages:
- nextcloud-php74...
- php74-pecl-imagick-im7...
- php74-bcmath...
- php74-gmp...
- nginx...
- mysql57-server...
nextcloud successfully upgraded!
