Plex Plugin Problem...
Sir Bogoff
You guys rock. just wanted to get that out of the way.
I have one tiny issue. Plex on my freenas server works like a charm in my house but as soon as I step out of my local network, no one can play anything. They can access the server by IP (port forwarding is setup and connects) but it then tells them that they are not authorized. I am not totally sure if this is a permissions problem on Freenas or something in PLex. I was using plex on a windows seven machine and did not have this problem but wanted to get away from that. More help if need be. This is what is seen. The screen they get to has a message on it. It shows the normal background but as soon as they choose a movie to watch, the get a message "Select Quality" and then under that, the get three lines that all say "Nan Undefined". No matter which they then click on, the next screen says "Please check the permissions for this file". Please see attachments.
Any help would be gratefully appreciated.
Thank you in anticipation..
mikipao
I have the same problem on my HP N54L with FreeNAS 9.2 64bit. Any help would be appreciated...
tnx
