plex on 11.2 Beta setup
I hope someone can point me in the right direction as I am a new user to freenas, I have freenas setup ok (I think) i have smb shares that can be accessed from my windows laptops so all is good in that respect however i can't for the life of me get plex to load anything, I can access plex via the webui but nothing loads, there is a jail for plex but I am at a loss on how to link it all up, any help with this will be great.
Thanks
SavageAUS
You need to mount the datasets inside the jail. Plenty of topics about this.
SavageAUS
Is that by adding a new mount point? If it is I have tried that and it still doesn't work:(:(:(:(
Can you show how your trying to mount them?
I've went into the plex jail, create new mount point and my source is /mnt/Joshua but when i try to put in a destination i get either folder doesn't exist or it just doesn't do anything in the plex webui,
It looks like this will take me a bit longer to suss out that I have time for at the moment, I have to go back to work at the moment but i will be finished in around an hour or so, would you mind if i sent you a private massage when I am home and you can give me a little hand to sort this out, Sorry for being such a noob but i'v only just started using freenas, I was using "omv" but it wasn't stable enough, I really appreciate you time. Thank you. (I will upload photos for you when I finish work)
