Plex - No PMS Plugin Logs
BorisJ
Hi
I've been running the plex plugin for quite a while now without issue. I'm trying to install WebTools2, the UnSupportedApps store replacement, I have it only half working. I started looking into my issue and found I need some Logs from the 'Jails/plexmediaserver_1/var/db/plexdata/Plex Media Server/Logs/PMS Plugin Logs' folder but I have nothing listed.... I checked the permissions and they look right to me. see the screen shot. I'm using the latest version of the plugin and I have restarted the jail to no avail....
Can anyone offer any assistance?
mgb
I'm having the exact same issue. I'm trying to fix a broken channel and can't seem to get it to log anything.
Any luck?
Joshua Parker Ruehlig
Any luck?
are you on version 0.9.15.3? I just pulled in a change that apparently fixed logging on freebsd
mgb
Just updated and now the log files are present in /var/db/plexdata/Plex Media Server/Logs/PMS Plugin Logs
Thanks!
Thanks!
no, prob =]
