plex jail DHCP not working
RJGamer1002
hey, I'm having a problem when I try to start plex jail on FreeNAS 11.2-RC1
idk if this is a bug or not. the media and the root are on separate pools. their are images.
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 541, in start
iocage.start()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1628, in start
callback=self.callback
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__
self.__start_jail__()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 413, in __start_jail__
silent=self.silent)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 81, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
RuntimeError: mount: /mnt/media/plex: Operation not supported by device
jail: /sbin/mount -t None -o rw /mnt/media/plex /mnt/root/iocage/jails/plex/root/media: failed
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 980, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1007, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 938, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 923, in run_in_executor
m0nkey_
Does the destination directory exist? It's having trouble mounting the dataset. Typically the path to the iocage jail is /iocage/jails/<jailname>/root/.
RJGamer1002
Yes the destination directory exist and The error only happen when they are in separate pools. When the source and the destination are in the same pool it work fine.
DrKK
FreeNAS Generalissimo
RJGamer1002
How we do that?
DrKK
bugs.freenas.org
RJGamer1002
