integrapynoy
- Oct 22, 2018
I had a plex plugin installed and running in 11.2 BETA3 and after i updated to RC1 the jail is missing and when i click on installed plugins i get this error. Please help!!
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 462, in list_resource
resource_list = iocage.list("all", plugin=True)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1150, in list
quick=quick
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_list.py", line 75, in list_datasets
_all = self.list_all(ds)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_list.py", line 153, in list_all
conf = iocage_lib.ioc_json.IOCJson(mountpoint).json_load()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 407, in json_load
conf = self.json_check_config(conf)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 910, in json_check_config
with open(freebsd_version, "r") as r:
FileNotFoundError: [Errno 2] No such file or directory: '/mnt/iocage/releases/EMPTY/root/bin/freebsd-version'
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1043, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 980, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1007, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 938, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 923, in run_in_executor
