raulico
- Nov 6, 2017
i'm an happy user of freenas and plex since a couple of years, but after the last upgrade to this version, if i update the library, the plex service media scanner remain active using 450% of cpu, and if i do a couple of sequential scans of library folder the cpu burns, and i see double or triple media scanner services on.
It happens only when new folder is found, if i do it without a new folder, it works properly and after finishin scan the service is closed regularly.
What can i check?
thanks
What can i check?
thanks
