Grinas
- May 4, 2017
Hey,
I want to be able to scan my plex libraries from the command line but am having trouble defining the environment variables.
When i run the command in the following docs with the path to my plexmediaserver i get the error
I defined the environment variable in the .profile but after exiting and renetering the jail i still get the same error when i run the Plex scanner command
.profile contents
output from Plex Media Scanner
Thanks for any help
export: Command not found.
.profile contents
LD_LIBRARY_PATH="/usr/local/share/plexmediaserver-plexpass/Plex_Media_Server" export LD_LIBRARY_PATH
/usr/local/share/plexmediaserver-plexpass/Plex\ Media\ Scanner --list Could not find platform independent libraries <prefix> Could not find platform dependent libraries <exec_prefix> Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>] ImportError: No module named site
Thanks for any help
