Lantana121
- Nov 11, 2013
Running Freenas 9.1.1 for about a year. Have (4) 2TB drives with 8gb ram. System used primarily as storage for movies and tv shows using XBMC.
Problem is suddenly system is very sluggish. Long time to change movies and significant shuddering while watching movies making them un-watchable. Drives are all reported as healthy. Only change I can notice in the reporting tab is the physical memory utilization has suddenly dropped significantly. Historically uses about 6gb and has 2gb free. Now reporting less than 1gb used and 7gb free.
Does not appear to be networking issue as internet gaming and watching shows online run fine. Have checked that network cables are secured and restarted everything.
Any ideas?
Any ideas?
