Slow performance on rebuild
Siege801
Hi Everyone,
Sorry, I know the title is generic, but there are enough performance quirks going on that I don't know how to be more specific.
Thanks in advance for reading.
I'm looking for any advice available. The purpose of this rig is to serve CalDAV via Nextcloud to a handful of users; Occasional Nextcloud browsing; and Media sharing via NFS to a Plex server (hosted on another device).
Summary list of issues:
  1. Poor transfer / write speeds
  2. Unable to mount with nfs (possibly performance related?)
  3. GUI unable to save changes
Here is my rig:
  • CPU: 6 CPUs x Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz
  • RAM: 32Gb RAM
  • Motherboard: ASRock Z390 Pro4 ATX LGA1151
  • Software: TrueNAS-12.0-U4
Hard Drives:
  • 6 x 2Tb Seagate ATA Disks running in RaidZ2 (~8Gb usable)
    • POOL_BigData
      • MEDIA Dataset
      • NCDATA Dataset
      • iocage Dataset (currently with only Nextcloud installed into it)
  • 2 x 16Gb USB3 boot-pool. N.B. The original plan was to run TrueNAS from a 500Gb NVM drive, but I found out all too late that the motherboard disables one of the SATA ports if I use one of the NVM connectors. I figured a striped USB install wouldn't be too much of an issue. Please advise if I'm wrong as there seem to be differing opinions out there.
Initially, I had this configured within a VMWare / ESXi configuration, but for data reliability reasons I've done a rebuild to a baremetal TrueNAS installation. While configured under ESXi, the TrueNAS VM had only 16Gb RAM assigned, with 4x2Tb SATAs at RaidZ1. Under this configuration, the read/write/mount performance was acceptable. Somehow, now, having installed TrueNAS directly to the box (no more ESXi here), the performance has bombed out:
Issue #1: Transfer speeds
I'm in the process of trying to copy data back to the TrueNAS machine. I currently have one computer uploading data via rsync/ssh. Each file is transferring at an average of 60.0MB/s, which I think is reasonable? However, if I spin up a second computer to upload data, computer A continues as is, while computer B can't even upload a single file - rsync tells me the transfer starts at about the same (60.0Mb/s), but before it's even uploaded more than a few Kbs, it drops down to a rate of around 100Kb/s and basically freezes. I would have thought, at worst, both transfers would share out the resources and level out with an even split of transfer speed?
Issue #2: NFS Mount woes
Secondly - I can't seem to mount to the TrueNAS box using NFS. From one Debian-based laptop, I have the following fstab entry:
192.168.1.x:/mnt/POOL_BigData/MEDIA /media/user/nas_media nfs rw,noatime,hard,intr,rsize=131072,wsize=131072,timeo=150,retrans=3 0
Then, running:
$ sudo mount /media/user/nas_media
results in:
mount.nfs: requested NFS version or transport protocol is not supported
Previously the error after a long pause was:
NFS mount error: mount.nfs mount system call failed
The change between the errors was either a TrueNAS reboot, or attempting to switch between NFSv3 and NFSv4. I say attempting, because when I go into Services -> NFS and toggle the NFS version, hitting Save then just gives me a blue spinning wheel of "Please wait" death (Issue #3 if you will).
NFS Configuration
Services -> NFS:
Enabled
Number of servers: This originally was set to 4 - I've also increased to 6 as per output from sysctl -n kern.smp.cpus
NFSv4 - Enabled: I have also tried disabled - see above on issue with toggling
Relevant Usage Statistics:
Memory:
31.9GiB total available
Free: 1.5 GiB
ZFS Cache: 20.3 GiB
Services: 9.8 GiB
Physical over an hour:
Min; Mean; Max
  • Wired: 0; 28.05GiB; 28.95GiB
  • Inactive: 20.31GiB; 28.35GiB; 29.11GiB
  • Laundry: 1.36GiB; 1.39GiB; 1.61GiB
  • Active:1.24GiB; 1.26GiB; 1.49GiB
  • Free: 704.3MiB; 1.43GiB; 9.34GiB
Swap Utilization over an hour:
Min; Mean; Max
  • Used: 0; 260.51MiB; 289.37MiB
  • Free: 4GiB; 4GiB; 4GiB
CPU:
24% Avg Usage
  • Threads: 7 threads
  • Highest Usage: $ (Thread #) - doesn't seem to be populating - under Reporting - it shows the following values:
    • Interrupt: 0.09 Mean; 0.38 Max
    • System: 4.98 Mean; 16.36 Max
    • User: 8.67 Mean; 21.85 Max
    • Nice: 8.67 Mean; 21.85 Max
    • Idle: 99.45 Mean; 100 Max
  • Hottest:doesn't seem to be populating - under Reporting - it's sitting at:
    • Mean of 93F
Network (Min; Mean; Max)
  • Octets Rx: 4.61Kb; 1.9Mb; 136.68Mb
  • Octets Tx: 55.32Kb; 188.95Kb; 3.08Mb
  • Overlap:4.61Kb; 102.44Kb; 3.08Mb
Disk I/O
da0 and da1 - the boot-pool over an hour period:
Min; Mean; Max (both drives had very similar values)
  • Read: 0; 7.89KiB; 395.88KiB
  • Write: 0; 367.96; 30.81KiB
ada0, 1, 2, 3, 4 and 5 - the data pool over an hour period:
Min; Mean; Max (all six drives had very similar values)
  • Read: 8.81KiB; 13.71MiB; 38.01 MiB
  • Write: 167.66KiB; 19.6MiB; 94.97MiB
I look forward to any advice / observations or requests for further information.
Kind Regards.
HoneyBadger
actually does care
Administrator
Before we dig too deeply, I want to rule out those drives as a potential pain point - please post exact model numbers eg: ST2000DM008
Compare against the list of known SMR drives maintained by @Yorick here:
and/or use the script created by @Basil Hendroff here:
Siege801
Hi There,
Thanks for the reply - and good shot.
Seagate - 3.5"ST2000DM0082TB BarracudaDM-SMR(2)
These are my drives... So... what does this mean? TrueNAS and my drives will never co-exist well?
ChrisRJ
Yes, you will need to get other disks, unfortunately
QonoS
You should be aware that Nextcloud runs a database. HDDs are too slow by some orders of magnitude to serve as storage for a database. (And those SMR drives esspecially.) Databases by default do writes with synchronous I/O and that is definitely a job for SSDs, or better enterprise SSDs.
Bargain: Buy 2 Intel Optane 16GB NVME drives. In used condition these are cheap to get and they last for an eternity. Create a mirrored pool of them and put the database there. It's amazingly performant.
ChrisRJ
@QonoS , I would add that your statement applies more to heavily utilized database servers in an enterprise context. Yes an HDD is not ideal for Nextcloud, but it should also not be a serious problem in a private context.
ChrisRJ
@Siege801 , does your board have a Realtek NIC by any chance? Those are known to cause loads of problems on FreeBSD and the recommendation is to buy an Intel server NIC instead.
