12pharoh21
- Jun 7, 2016
Hello all,
I have a new TrueNAS server that I have configured recently but I'm having some trouble with NFS shares. I have tried this on my other TrueNAS server and it does the same thing. I can mount the top level folder without a problem, but any child directories are not able to be mounted. My server config is as follows:
TrueNAS-12.0-U7
MB - ASUS SaberTooth X58
CPU - Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
RAM - 24GB
LSI MegaRAID SAS 9361-4i
LSI LSI00412 0.6 Meter Internal Cable SFF8643 to x4 SAS8482
-Disks - 4x8TB HGST SAS NAS drives in RAIDZ1
I have one pool spanning the whole drive array called Media, then a child dataset called Movies. I have setup the NFS share using /mnt/Media and running cat /etc/exports returns the following:
In my Ubuntu server I am trying to mount the Movies folder, but I get the following error
If I change the command to just mount /mnt/Media it will mount without an issue. Should the flag -alldirs not allow me to mount any of the child datasets? I have typically been using SMB shares in the past, but most everything I am using with this are Ubuntu servers, so I want to move to NFS shares instead. I tested this on my existing TrueNAS-12.0-U6 server and it did the same thing as this one. Is there a bug that won't allow you to mount child datasets?
TrueNAS-12.0-U7
RAM - 24GB
/mnt/Media -alldirs -quiet -network xxx.xxx.xxx.xxx/24
mount.nfs: timeout set for Tue Dec 21 17:26:46 2021 mount.nfs: trying text-based options 'vers=3,addr=xxx.xxx.xxx.xxx' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying xxx.xxx.xxx.xxx prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying xxx.xxx.xxx.xxx prog 100005 vers 3 prot UDP port 791 mount.nfs: mount(2): Permission denied mount.nfs: access denied by server while mounting xxx.xxx.xxx.xxx:/mnt/Media/Movies
