BrentFreeNAS
- Oct 19, 2016
I'm intermittently unable to mount a FreeNAS NFS share from ubuntu server 16.04.5LTS. It seems to happen once I restart FreeNAS. My solution in the past has been to retry continuously for a few days, to a week and eventually it would mount after several restarts. Once I'm able to mount once, I can remount with no issues from several machines, usually until I restart the NAS. In each case, I'm able to ping the NAS from the machine I'm trying to mount from, and I've also set permissions to 777 in the past to try and fix the problem, with no luck. I recently learned of the -v option when using mount and have this output:
The FreeNAS machine (192.680.50.200) has 192.168.80.1/24 as an authorized network in the nfs sharing section.
Does anyone have any insight as to what I'm doing wrong?
Thank you,
Brent
mount.nfs: timeout set for Fri Sep 28 11:41:00 2018 mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: trying text-based options 'vers=4,addr=192.168.50.200,clientaddr=192.168.80.201' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.50.200' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot UDP port 699 mount.nfs: portmap query retrying: RPC: Timed out mount.nfs: prog 100005, trying vers=3, prot=6 mount.nfs: trying 192.168.50.200 prog 100005 vers 3 prot TCP port 699 mount.nfs: portmap query failed: RPC: Timed out mount.nfs: Connection timed out
Thank you,
Brent
