fahadshery
- Sep 29, 2017
I created a
I then created the
Here is my share looks like in TrueNas:
When I try and mount it in Ubuntu using:
I get the following error:
On the TrueNas logs I am seeing these:
What am I doing wrong?
I created a
dataset
called nextcloud
to host next cloud data. I assigned the user to be nextcloud
and denied everyone else.I then created the
NFS
share as normalHere is my share looks like in TrueNas:
root@truenas[~]# cat /etc/exports /mnt/tank/nextcloud -alldirs -network 192.168.1.0/24
sudo mount 192.168.1.167:/mnt/tank/nextcloud /home/username/nextcloud_mounted/ -vv
mount.nfs: timeout set for Fri Mar 12 15:35:00 2021 mount.nfs: trying text-based options 'vers=4.2,addr=192.168.1.167,clientaddr=192.168.1.171' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'vers=4.1,addr=192.168.1.167,clientaddr=192.168.1.171' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'vers=4.0,addr=192.168.1.167,clientaddr=192.168.1.171' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=192.168.1.167' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 192.168.1.167 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 192.168.1.167 prog 100005 vers 3 prot UDP port 916 mount.nfs: mount(2): Input/output error mount.nfs: mount system call failed
Mar 11 22:53:19 truenas 1 2021-03-11T22:53:19.127907+00:00 truenas.local mountd 74970 - - mount request denied from 192.168.1.171 for /nextcloud
