Permanent Errors
baileys22
Hello all,
Can someone tell me how to clear this error? My pool shows unhealthy because of it. I moved this pool to a new system from an unstable one using an ASUS motherboard and imported the config and still get this message. I am running 13.0 U2 but below name is 13.0 U3. I am wondering if this is a STAGED corrupted update download that is from when the prior system rebooted. Thanks for any help!
artlessknave
forum rules.
I believe
 zpool clear boot-pool
is what you want. Im not sure how to handle the bad file. might be able to just rm it? running a new update ought to verify it, find it bad, and replace it, but I've never encountered this.
joeschmuck
Old Man
You are correct, it's likely a bad download of the update file. The file is damaged and you will need to remove it. You should be able to rm the file. The zpool clear command is apt to do nothing at all until the offending file is removed, then run a scrub, ensure there are no more corrupt files.
joeschmuck
Old Man
Glad you got the problem resolved.
