I just recently put together my first freenas box, after lurking on these forums for quite some time (prior to making an account.) After my initial burn-in testing, I started to load my freenas box with my files. A bit to my surprise, my files ended up transferring fairly consistently between 80-85 MB/s (using CIFS). I have gigabit connections across the board, so I was expecting results in the mid-to-high 90 MB/s range.
NAS:
Asrock C2750D4I
16 GB Crucial 102472BD160B ECC UDIMM
4x 4GB WD Reds in RaidZ2
Silverstone DS380 + Silverstone 450 watt power supply (not that those should effect this.)
PC:
i5 3750K Intel (Windows 7 Pro)
32 GB 1866 G.Skill RAM
Asrock Z77 Extreme6/TB4
Drives: 2TB Seagate, 1TB WD Green, 500GB Samsung Evo
Switch: DLink DGS-1100-16
To rule out drive speed on my PC, I transferred some of my files to the Samsung Evo, then transferred them to my NAS. These were videos ~3GB each. The average transfer speed was around 82 MB/s. One thought I have to the cause of this would be the Broadcom NIC doesn't quite do true 1Gbps speeds?
My other thought was that the 4 discs could not handle that writing any after than that. As such, once the files were loaded, I transferred them back to PC. The performance was similar (80-85 MB/s).
I'm thinking these results are as good as I am likely to get, but I wanted to check. In reviewing a ton of posts both on the Freenas forums and others, I've seen plenty of results much worse than what I'm getting. I wanted to get a feeler out there for others who have a similar build to me to see what their CIFS transfer speeds are.
In the meantime, my next step will be to test the CIFS speeds using a Linux Mint laptop wired in, as I have read a couple of posts from Cyberjock stating that CIFS works better from a linux client than windows.
Many thanks in advance.
NAS:
Asrock C2750D4I
PC:
