I've got 5x3TB WD Red drives that I'm slowly replacing with 5x5TB Toshiba drives. My mobo has 6 SATA ports, so I'm doing it by plugging in one new drive, resilvering, then taking out the old drive and moving onto the next one. The first two went fine, but on the third one I moved the in-used 3TB drive to a new port and put a 5TB in its place. When I booted, I got a bunch of these errors:
I turned the machine off and tried to reseat the cables on the affected drive (which is the 3TB one I moved). Still getting the errors. SMART indicates no problems. I ran a short self-test with no errors. A long test is running right now
Here's the output of smartctl -x -q no serial /dev/ada0:
It's resilvering right now:
Does this suggest the drive might be going bad? Or maybe the cable is bad? Or the motherboard?
Dec 7 19:36:34 mickey (ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 90 a0 50 40 5d 01 00 00 00 00 Dec 7 19:36:34 mickey (ada0:ahcich0:0:0:0): CAM status: Uncorrectable parity/CRC error Dec 7 19:36:34 mickey (ada0:ahcich0:0:0:0): Retrying command Dec 7 19:36:34 mickey (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 01 ae a3 50 40 5d 01 00 00 00 00 Dec 7 19:36:34 mickey (ada0:ahcich0:0:0:0): CAM status: Uncorrectable parity/CRC error Dec 7 19:36:34 mickey (ada0:ahcich0:0:0:0): Retrying command
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68N32N0
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Dec  7 21:03:57 2019 CST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Write SCT (Get) Feature Control Command failed: Input/output error
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      (  41) The self-test routine was interrupted
                                        by the host with a hard or soft reset.
data collection:                (33120) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 352) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   165   165   021    -    6708
  4 Start_Stop_Count        -O--CK   100   100   000    -    26
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   100   253   000    -    0
  9 Power_On_Hours          -O--CK   086   086   000    -    10516
 10 Spin_Retry_Count        -O--CK   100   253   000    -    0
 11 Calibration_Retry_Count -O--CK   100   253   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    26
192 Power-Off_Retract_Count -O--CK   200   200   000    -    9
193 Load_Cycle_Count        -O--CK   200   200   000    -    33
194 Temperature_Celsius     -O---K   120   113   000    -    30
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   100   253   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS       1  Device vendor specific log
0xb7       GPL,SL  VS      56  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Interrupted (host reset)      90%     10516         -
# 2  Short offline       Completed without error       00%     10516         -
# 3  Short offline       Interrupted (host reset)      10%     10516         -
# 4  Short offline       Completed without error       00%     10515         -
# 5  Extended offline    Completed without error       00%     10389         -
# 6  Short offline       Completed without error       00%     10257         -
# 7  Extended offline    Completed without error       00%        24         -
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    30 Celsius
Power Cycle Min/Max Temperature:     29/31 Celsius
Lifetime    Min/Max Temperature:     24/37 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/65 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (75)
Index    Estimated Time   Temperature Celsius
  76    2019-12-07 13:06    33  **************
 ...    ..( 77 skipped).    ..  **************
 154    2019-12-07 14:24    33  **************
 155    2019-12-07 14:25    32  *************
 ...    ..( 41 skipped).    ..  *************
 197    2019-12-07 15:07    32  *************
 198    2019-12-07 15:08    33  **************
 ...    ..( 61 skipped).    ..  **************
 260    2019-12-07 16:10    33  **************
 261    2019-12-07 16:11    32  *************
 ...    ..( 68 skipped).    ..  *************
 330    2019-12-07 17:20    32  *************
 331    2019-12-07 17:21    31  ************
 ...    ..( 42 skipped).    ..  ************
 374    2019-12-07 18:04    31  ************
 375    2019-12-07 18:05    30  ***********
 ...    ..( 57 skipped).    ..  ***********
 433    2019-12-07 19:03    30  ***********
 434    2019-12-07 19:04     ?  -
 435    2019-12-07 19:05    29  **********
 436    2019-12-07 19:06    29  **********
 437    2019-12-07 19:07     ?  -
 438    2019-12-07 19:08    29  **********
 439    2019-12-07 19:09     ?  -
 440    2019-12-07 19:10    29  **********
 441    2019-12-07 19:11    29  **********
 442    2019-12-07 19:12    29  **********
 443    2019-12-07 19:13    30  ***********
 ...    ..( 67 skipped).    ..  ***********
  33    2019-12-07 20:21    30  ***********
  34    2019-12-07 20:22    31  ************
 ...    ..( 11 skipped).    ..  ************
  46    2019-12-07 20:34    31  ************
  47    2019-12-07 20:35    30  ***********
  48    2019-12-07 20:36    33  **************
 ...    ..( 26 skipped).    ..  **************
  75    2019-12-07 21:03    33  **************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              26  ---  Lifetime Power-On Resets
0x01  0x010  4           10516  ---  Power-on Hours
0x01  0x018  6     22491831389  ---  Logical Sectors Written
0x01  0x020  6       562725686  ---  Number of Write Commands
0x01  0x028  6    168023015275  ---  Logical Sectors Read
0x01  0x030  6       952990205  ---  Number of Read Commands
0x01  0x038  6      3497861632  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           10461  ---  Spindle Motor Power-on Hours
0x03  0x010  4           10461  ---  Head Flying Hours
0x03  0x018  4              43  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               1  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4               9  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               6  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              30  ---  Current Temperature
0x05  0x010  1              32  ---  Average Short Term Temperature
0x05  0x018  1              28  ---  Average Long Term Temperature
0x05  0x020  1              37  ---  Highest Temperature
0x05  0x028  1              18  ---  Lowest Temperature
0x05  0x030  1              35  ---  Highest Average Short Term Temperature
0x05  0x038  1              19  ---  Lowest Average Short Term Temperature
0x05  0x040  1              33  ---  Highest Average Long Term Temperature
0x05  0x048  1              22  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              65  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             201  ---  Number of Hardware Resets
0x06  0x010  4              83  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2           26  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2           26  R_ERR response for host-to-device data FIS
0x0005  2           10  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2           10  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2           28  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2           30  Device-to-host register FISes sent due to a COMRESET
0x000b  2           34  CRC errors within host-to-device FIS
0x000d  2            2  Non-CRC errors within host-to-device FIS
0x000f  2           26  R_ERR response for host-to-device data FIS, CRC
0x0012  2            8  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4         5420  Vendor specificIt's resilvering right now:
  pool: Media-pool
 state: DEGRADED
status: One or more devices is currently being resilvered.  The pool will
        continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
  scan: resilver in progress since Sat Dec  7 19:46:21 2019
        2.72T scanned at 602M/s, 1.78T issued at 395M/s, 10.4T total
        364G resilvered, 17.07% done, 0 days 06:23:11 to go
        NAME                                              STATE     READ WRITE CKSUM
        Media-pool                                        DEGRADED     0     0     0
          raidz1-0                                        DEGRADED     0     0     0
            gptid/93167540-1915-11ea-8fec-0cc47a0128c1    ONLINE       0     0     0
            gptid/454e0a58-17ca-11ea-a5c1-0cc47a0128c1    ONLINE       0     0     0
            gptid/c530b0ff-f7f1-11e7-b8a6-0cc47a0128c1    ONLINE       0     0     0
            gptid/c5fc40e4-f7f1-11e7-b8a6-0cc47a0128c1    ONLINE       0     0     0
            replacing-4                                   FAULTED      0     0     0
              gptid/eec234f6-c031-11e8-afc1-0cc47a0128c1  FAULTED      0     0     0  too many errors
              gptid/845a46c5-195c-11ea-9ec7-0cc47a0128c1  ONLINE       0     0     0
errors: No known data errorsDoes this suggest the drive might be going bad? Or maybe the cable is bad? Or the motherboard?
