I used the packaged Owncloud V6.01 - I had to backup - then delete my old V5 Owncloud to get this to install.
Now I get the yellow bar at the top of Owncloud telling me to update.
I go to the update centre and the update then errors:
Upgrade is not possible. Make sure that your webserver has write access to the following files and directories:
/usr/pbi/owncloud-amd64/owncloud/3rd party
and lists lots of files / directories
the last line error is:
The Update was unsuccessful.
I see the idea of using the updater as the BEST WAY of upgrading.
Does anyone know how to fix this problem?
