Freenas & OwnCloud - WebDav Problem...
tedeu
Hy,
First of all helo, I am George, long time reader, first time poster :)
I have a problem with WebDav.
I installed OwnCloud as a plugin from Freenas with jail.
My ownCloud version 5.0.12
My FreeNAS version 9.2.0
If i go to http://OWNClouwPath/remote.php/webdav/ with a browser, i can see a page with all my files
Index for /
Generated by SabreDAV 1.7.6-stable (c)2007-2013
If on the other hand i try to connect to it by any other means, it says it cannot connect as if the device isn't there
In owncloud log i have this:
LOG Debug
Debug core include path for class "OCA_FirstRunWizard\Config" starts with "apps/" 2014-01-22T08:47:42+00:00
Debug core Adding default user backend WEBDAVAUTH. 2014-01-22T08:47:42+00:00
Debug core Adding default user backend WEBDAVAUTH. 2014-01-22T08:48:10+00:00
Debug core Adding default user backend WEBDAVAUTH. 2014-01-22T08:48:06+00:00
Debug core Adding default user backend WEBDAVAUTH. 2014-01-22T08:47:55+00:00
Debug core Adding default user backend WEBDAVAUTH. 2014-01-22T08:47:46+00:00
Debug core Adding default user backend WEBDAVAUTH. 2014-01-22T08:47:43+00:00
Debug search_lucene adding /RAPOARTE/DEFECTS OF PICS/DSCN0654.JPG 2014-01-22T08:47:43+00:00
Debug search_lucene found 0 hits 2014-01-22T08:47:43+00:00
Debug search_lucene searching hits for pk:ca68ef8c4e383f6dd9b3829c465a68cd 2014-01-22T08:47:43+00:00
Debug core include path for class "Zend_Search_Lucene" starts with "apps/" 2014-01-22T08:47:43+00:00
LOG
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:10:14+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:09:55+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:09:54+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:09:44+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:09:04+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:08:57+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:08:21+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:08:16+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:08:10+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:07:58+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-21T13:07:58+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:07:49+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:07:41+00:00
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T13:07:33+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T12:07:56+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T12:07:45+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T12:05:55+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T12:04:58+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T12:03:03+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T12:02:31+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T12:02:12+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T12:01:38+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:58:47+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:58:11+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:57:05+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:56:52+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:52:13+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:51:52+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:51:42+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:51:35+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:51:28+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:51:04+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:50:53+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:50:21+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:49:39+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:49:04+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:48:40+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::touchHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:48:37+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:48:36+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:48:25+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:47:34+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:47:15+00:00
Error hook error while running hook (\OC\Files\Cache\Updater::writeHook): SQLSTATE[HY000]: General error: 5 database is locked 2014-01-21T11:47:10+00:00
LOG Fatal
Fatal PHP Cross-reference streams are not supported yet. at /usr/pbi/owncloud-amd64/www/owncloud/apps/search_lucene/3rdparty/Zend/Pdf/Parser.php#318 2014-01-21T11:37:56+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-20T07:29:18+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-20T07:29:17+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-20T07:29:00+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-20T07:28:48+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-17T12:55:13+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-17T12:53:41+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T17:37:15+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T17:36:43+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T17:36:27+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T10:45:37+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T10:45:23+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T10:45:20+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T10:45:18+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T10:45:13+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T10:45:09+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T10:45:00+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:47:54+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:47:36+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:47:27+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:47:19+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:47:04+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:46:54+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:46:42+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:46:37+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:46:33+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:46:20+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:46:15+00:00
Fatal PHP SQLSTATE[HY000]: General error: 5 database is locked at /usr/pbi/owncloud-amd64/www/owncloud/lib/db.php#1075 2014-01-16T09:46:09+00:00
What can i do ?
I also don't like that in fatal log level I have so many entries ...
What do you recommend?
Thank you
George.
