clamschlauder
- Feb 23, 2013
Hello all,
I upgraded through the Admin Control on the //IP/owncloud webpage. Showed that it was going into maintenance mode and not much seemed to happen. My owncloud still works. I assume that it updated. Only issue is that the webpage is now blank. Technically since I cant verify the version through the webpage, I am not sure if it is still on version 7.0.4 or not.
I used J Ruehlig's nice guide to install inside a jail through shell.
I have SSL Certificates setup.
I went through all of the config files in the guide to make sure nothing was overwritten. Some things needed changing but most of it was still the same. I dont have anything important on OwnCloud but I will be dropping Dropbox soon (meaning I am not afraid to do something that might screw up the jail install)
Any hints on where to start would help.
** Seems to be something about apps not being disabled during install according to Owncloud Forums. I dont have any apps installed so this seems weird. One user suggested "A quick fix could be to check your oc_appconfig database table and to set all non core apps to enabled = no, but there are probably better ways to deal with the situation."
