'overwritewebroot' => '/owncloud' error
Mam Ruoc
I just installed the owncloud plugin and started it up.
I then added:
'overwritewebroot' => '/owncloud',
in config.php:
/usr/pbi/owncloud-amd64/www/owncloud/config/config.php
The result is that it seems to forward me to "correct" path, but I get:
The requested URL /owncloud/index.php/apps/files/ was not found on this server.
I am not sure what to do from here, anybody can help me?
BigDave
FreeNAS Enthusiast
I don't use that plugin, but here's an excellent guide that may be helpful.
Use the forums search feature to find more posts about Owncloud.
Joshua Parker Ruehlig
I then added:
in config.php:
are you trying to change owncloud'd URL? that's not how, you need to change that in your webserver (for the plugin its apache).
that setting is something you just change after. it tells owncloud what your webroot is if a script is triggered not from a webrowser (where OC can figure it out), for example when OC sends out notification emails from cron. otherwise links in this email won't know the correct URL
Mam Ruoc
Of course! Why didn't I think about it?!
For later reference, the change has to be done in:
/usr/pbi/owncloud-amd64/etc/apache22/Includes/owncloud.conf
